Author Topic: How To Video: Wiring a Control Panel for Beginners  (Read 5712 times)
  • Last login:October 20, 2023, 11:39:06 pm
« on: March 04, 2008, 02:35:56 pm »
Here's a video that I put together on the basics of wiring a control panel (for beginners).
I don't go in depth about crimping or soldering.  Also, I used micro switches on my buttons.
I apologize for the quality of the video in advance, as I had to compress it to be acceptable for Youtube.
Enjoy!
~ DeLuSioNaL
[youtube]http://www.youtube.com/watch?v=kSdH2w1SJN4[/youtube]
« Last Edit: March 04, 2008, 02:57:06 pm by DeLuSioNal29 »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: How To Video: Wiring a Control Panel for Beginners
« Reply #1 on: March 04, 2008, 03:47:02 pm »
Just wanted to  :applaud: for taking the time to put this together.
Working: Not Enough
Projects: Too Many
Progress: None
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: March 04, 2008, 04:03:18 pm »
Didn't learn anything myself, but I'm sure this will help out plenty of people just getting started.
Great video. Good work.
:cheers:  :applaud:  :woot
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #3 on: March 04, 2008, 04:11:28 pm »
LoyalistRevolt
  • Last login:June 19, 2008, 08:52:07 am
  • SEGA!
« Reply #4 on: March 04, 2008, 04:24:23 pm »
Is this the same for a console controller?
Not posting doesn't make you a noob, ignorance, stupidity, laziness, and talking trash make you a noob.
Just cause I don't post in threads doesn't mean I don't read the threads...
Kaytrim
  • I'm too nice a guy
« Reply #5 on: March 04, 2008, 04:30:58 pm »
Excelent video.  :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud:
You will need to solder wires to the controller pad.  Depending on the type of controller you can daisy chain the ground.  Some of the newer controllers you can't because each button has it's own separate ground.  Microsoft XBox 360 pads are the worst in this area.  Also you can't replace the thumb sticks on the controller with a standard digital joystick.  The thumb sticks are analog so you can do the fine targeting required.
Tones of information at this link about hacking controllers (aka game pads).
TTFN
Kaytrim
LoyalistRevolt
  • SEGA!
« Reply #6 on: March 04, 2008, 04:42:55 pm »
Thanks that helped alot but I would like a specific tutorial on dreamcast controllers.
« Reply #7 on: March 04, 2008, 05:01:50 pm »
Hmmm, that's something I can work on with a buddy of mine who is a Dreamcast guru.  I'm associated with RetrowareTV.com and we could always shoot something like that.  I'll ask him to see what he thinks.
On the other hand, I had always wanted to make an Xbox Mod that will interface with an ipac for a Bartop arcade.  The reason being is that Xboxes are dirt cheap now (original Xboxes) and it would cost next to nothing to softmod it to play MAME.
~ DeLuSioNaL
Kaytrim
« Reply #8 on: March 04, 2008, 05:43:46 pm »
Here is a pic of a dreamcast controller with solder points marked.  As long as you scrape off the black stuff down to copper you have a good place to solder your wire.  This is a single ground pad so you can daisy chain the ground connections on your buttons and joystick.  Also this is a digital pad instead of an analog stick so it maps directly to a standard joystick.
« Last Edit: March 04, 2008, 05:46:21 pm by Kaytrim »
« Reply #9 on: March 11, 2008, 05:12:13 pm »
