Main > Main Forum
How To Video: Wiring a Control Panel for Beginners
Pages: << < (2/2)
Kaytrim:
Excelent video.  :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud:
--- Quote from: LoyalistRevolt on March 04, 2008, 04:24:23 pm ---Is this the same for a console controller?
You will need to solder wires to the controller pad.  Depending on the type of controller you can daisy chain the ground.  Some of the newer controllers you can't because each button has it's own separate ground.  Microsoft XBox 360 pads are the worst in this area.  Also you can't replace the thumb sticks on the controller with a standard digital joystick.  The thumb sticks are analog so you can do the fine targeting required.
Tones of information at this link about hacking controllers (aka game pads).
TTFN
Kaytrim
LoyalistRevolt:
Thanks that helped alot but I would like a specific tutorial on dreamcast controllers.
DeLuSioNal29:
--- Quote from: LoyalistRevolt on March 04, 2008, 04:42:55 pm ---Thanks that helped alot but I would like a specific tutorial on dreamcast controllers.
Hmmm, that's something I can work on with a buddy of mine who is a Dreamcast guru.  I'm associated with RetrowareTV.com and we could always shoot something like that.  I'll ask him to see what he thinks.
On the other hand, I had always wanted to make an Xbox Mod that will interface with an ipac for a Bartop arcade.  The reason being is that Xboxes are dirt cheap now (original Xboxes) and it would cost next to nothing to softmod it to play MAME.
~ DeLuSioNaL
Kaytrim:
Here is a pic of a dreamcast controller with solder points marked.  As long as you scrape off the black stuff down to copper you have a good place to solder your wire.  This is a single ground pad so you can daisy chain the ground connections on your buttons and joystick.  Also this is a digital pad instead of an analog stick so it maps directly to a standard joystick.
DeLuSioNal29:
--- Quote from: mr.Curmudgeon on March 04, 2008, 04:11:28 pm ---Awesome! Added to the Wiki.
http://wiki.arcadecontrols.com/wiki/Controls#How_To_Videos
Perhaps you can add the How to for the Marquee to the Wiki as well?
http://forum.arcadecontrols.com/index.php?topic=77411.0
~ DeLuSioNaL
Pages: << < (2/2)
Go to full version
