Author Topic: Virtual Cabinet Design  (Read 1792 times)
Zobeid
  • Last login:April 21, 2021, 10:36:32 pm
« on: February 29, 2008, 11:57:10 am »
As I get into designing control panels and other things, one problem was that a lot of the tools other people pointed me toward didn't work on my Mac.  I'm also not familiar with the heavy-duty modeling tools, and I know they've got a steep learning curve.  So I improvised.
First I turned to OmniGraffle for laying out my control panel.  The great thing about this program is that it's very easy to move things around and try different layouts.  I went through about 25 revisions before I figured it out completely.   Some examples. . .
http://zobeid.zapto.org/caviar/image/CP01.png
http://zobeid.zapto.org/caviar/image/CP08.png
http://zobeid.zapto.org/caviar/image/CP18.png
http://zobeid.zapto.org/caviar/image/CP24.png
So far, so good.  But the next problem came after I decided I wanted a rotating LCD monitor.  I couldn't pull an existing cabinet plan off the shelf, I had to design my own.  This was a 3D problem.  I felt intuitively that everything should fit into the dimensions I wanted, but I needed a way to verify it.
I went into Second Life and started building.  The biggest hassle was constant unit conversions, because everything in SL is measured in meters!  But anyhow, here's what I ended up with:
http://zobeid.zapto.org/caviar/image/mame/mockup_01.jpg
Rotating 19-inch LCD, inclined back 40 degrees.  Full-sized speakers and marquee.  My chosen control layout, with no awkward "front porch" hanging off the cabinet.  Dimensions similar to a classic Defender machine.
Here's a close-up of the control panel:
http://zobeid.zapto.org/caviar/image/mame/mockup_02.jpg
It looks like everything should fit, and not be too cramped together.  Next I take the side panel off. . .
http://zobeid.zapto.org/caviar/image/mame/mockup_03.jpg
Again, my concern is that there's room for the monitor to rotate.  Looks like it should fit.  Notice the admin buttons tucked under the CP box!  So if you want to exit the game, you can reach under there. . .  but you'll never hit it by accident, and it's not taking up space on top of the CP.
Next I compare with a typical human figure, wondering if the CP height will be comfortable, monitor height and angle will be comfortable, marquee won't block the view of the screen, etc. . .
http://zobeid.zapto.org/caviar/image/mame/mockup_04.jpg
http://zobeid.zapto.org/caviar/image/mame/mockup_05.jpg
Looks good so far.  :)
MazzMn
  • Last login:March 19, 2013, 12:38:19 am
  • chicken, fight like a robot
    • The IceBox Oak Cocktail Table
Re: Virtual Cabinet Design
« Reply #1 on: March 01, 2008, 02:49:02 pm »
SecondLife to build cabinets...what a great idea!
In trying to build a cocktail cabinet, a friend and I were trying to imagine how or where our knees would bump into the cabinet, I wonder if comparing a virtual cabinet (to scale as you have done) against my avitar would have helped the situation?
Not that you need another tool, but I've seen several written up with Google Sketchup and that would certainly work on your mac
http://sketchup.google.com/
Zobeid
« Reply #2 on: March 01, 2008, 03:38:47 pm »
It could be helpful, but with a couple of caveats.
Firstly. . .  SL may be a 3D environment, but you're looking at it through a 2D monitor with no depth perception and without many of the cues we normally use to judge distance and sizes in real life.  When comparing two objects, it's best to put them right next to one another, and then position your camera facing them evenly from the side.
Secondly. . .  Don't trust the size of anybody (including yourself) or anything in SL unless you've measured it.  Everything in SL is made to Wonky Scale.  Ceilings are 20 feet high, most avatars are seven feet tall walking around on exaggerated, stilt-like legs, and they don't realize there's anything odd about it.  I even found an arcade with classic games in SL -- and the game cabinets were the size of kitchen refrigerators.  Yet they didn't look that odd at first glance, because there was nothing to compare them against.
SL was a natural for me because I've already been using it for a few years and was basically familiar with the building tools there.  I just discovered Sketchup a couple of days ago, so I'm very interested in learning to use it too.  :)
MazzMn
Re: Virtual Cabinet Design - Arcade in SecondLife
« Reply #3 on: April 19, 2008, 06:42:37 pm »
Zoebeid,
Have you seen the Insert Coin Arcade in SecondLife? Just bumped into it. They have reproduced some classic arcade machines and have developed some new games. The traditional games can't be played in SL yet, just provide links to flash games playable via a browser. However, it was a nice touch playing the sounds of many arcade games...sort of simulates walking through an arcade back in the day
Here is an SLURL http://slurl.com/secondlife/Flotsam%20Beach/115/182/22
« Last Edit: April 20, 2008, 04:07:35 pm by MazzMn »
Zobeid
« Reply #4 on: April 19, 2008, 09:23:37 pm »
I found that a while back, it's pretty neat.
I do think it's funny that the cabinets are so huge.  They're about nine feet tall, and my six foot tall avatar has to stand on a box to reach the controls and play them.
coltchillin
  • Last login:February 06, 2010, 05:28:43 am
    • My Midway replica project Flickr
« Reply #5 on: April 20, 2008, 06:22:06 am »
i like the chick.
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #6 on: April 20, 2008, 06:57:58 am »
I mean this not as an insult but I can't get it out of my head...
"You might be a furry if; You use SecondLife to do CAD Design."
« Last Edit: April 20, 2008, 07:57:48 am by DJ_Izumi »
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #7 on: April 20, 2008, 07:17:28 am »
I guess I'm doing this all wrong. To get my control panel height, I stood with my arms comfortably bent and measured the distance to the floor. The rest of the cab design was done using this amazingly sophisticated tool that rendered it in about 10 minutes.
 No virtual chick butts, but 3 MAME cabs and 2 dedicated. ;)
