Main > Main Forum
Anyone using a 25" Wells Gardner 25k7193 monitor for MAME?
pincky:
--- Quote from: urbecrisch on March 02, 2008, 01:26:54 am ---Actually the monitor's not bad to discharge cause the models we have are equipped with an auto-discharge which discharges the monitor when powered off (probably not 100%, but way less than other monitors). If you're a little timid to discharge, call chad and he'll walk you through it. I can help out too but I'd rather leave the actual discharging instructions to the "pro". If needed, I can show you what my discharge tool looks like. Just a long flathead screwdriver and some wiring connected to 2 alligator clips. Maybe 10 in parts. The website below is just a pic tutorial on discharging a monitor. My tool looks like the one pictured. Good luck!
http://www.arcadegames.net/sightsound/discharge.ppt#1
see its a story like that that scares the YOU KNOW WHAT OUT OF ME!
i've bought a digital multimeter and
Fluke 80K-40 High Voltage Probe
to do the discharge
I liked the way this guy does his discharged per this link
http://www.stickycarpet.com/pinx/md.html
Matter of fact i am buying a pair of rubber gloves
urbecrisch:
LOL! It's funny cause I was in the same boat as you when I discharged the first time. I've done the discharge twice so far with no problems. Never needed rubber gloves or special tools, just the $10 worth I mentioned before. I do understand where you're coming from so let me know how everything works out. Are you going to have arcadecup fix the monitor? The one pic I attached is the auto-discharge wire on the monitor and the other 2 pics are of the discharge tool I put together. Good luck!
pincky:
--- Quote from: urbecrisch on March 02, 2008, 02:15:46 pm ---LOL! It's funny cause I was in the same boat as you when I discharged the first time. I've done the discharge twice so far with no problems. Never needed rubber gloves or special tools, just the $10 worth I mentioned before. I do understand where you're coming from so let me know how everything works out. Are you going to have arcadecup fix the monitor? The one pic I attached is the auto-discharge wire on the monitor and the other 2 pics are of the discharge tool I put together. Good luck!
yes I am going to send it to arcadecup thanks alot for that link!!!
my monitor does have that same auto-discharge wire in that pic.
Heres the link
http://pincky.gotdns.com/Pictures/My%20Arcade%20Pictures/IMG_0911.JPG
http://pincky.gotdns.com/Pictures/My%20Arcade%20Pictures/IMG_0912.JPG
the second one shows it pluging in to the main board
Zebidee:
Zzzzzzappp!! :blowup:
Dudes, that first pic isn't an "auto-discharge wire". It is a grounding strap to minimise static on the screen. It does nothing to the 25,000 volts inside the tube. Don 't confuse yourself about this!
The discharging tool, on the other hand, looks mighty fine. Just clip the other end to something well grounded (or at least large and metal).
urbecrisch:
LOL, oops. Wrong PIC. Your right, that first PIC is the CRT ground wire which needs to be on for the auto-discharge to work. I recall having to cut the wire in half when I shipped it out cause it was connected to the neckboard. Thanks for the clarification.
