Author Topic: HELP mamewah and project 64  (Read 1532 times)
reko19
  • Last login:February 27, 2024, 12:43:51 pm
« on: February 26, 2008, 11:49:47 am »
Can't get it to even generate the games list. Depending on list_generation_method selected, I either get nowhere or get "missing plugin" message. My ini is attached, googled it till blue in the face. Any help would be greatly appreciated.
mchay
  • Last login:March 07, 2019, 09:16:04 am
Re: HELP mamewah and project 64
« Reply #1 on: February 26, 2008, 12:21:34 pm »
Are you using MAMEWAH 1.62b13?
reko19
« Reply #2 on: February 26, 2008, 12:28:46 pm »
yes I am
reko19
« Reply #3 on: February 26, 2008, 12:31:51 pm »
i also downloaded the ini and cracked exe from jcrouse site, still having same problem
gonzo90017
« Reply #4 on: February 26, 2008, 01:39:35 pm »
Please don't double post the same question.
For Nintendo64 download the wrapper and edit Project64Wrapper.cfg with your paths. Your ini should look something like this:
Code: [Select]
### n64.ini (mamewah v1.62) ###
emulator_title                            Nintendo 64
### List Generation Settings ###
rom_path                                  C:\juegos\n64\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      C:\juegos\n64\Project64Wrapper.exe "[rompath]\[name].[romext]"{dosbox}{safelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       C:\juegos\n64\snaps
movie_preview_path                        C:\juegos\n64\videos
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file                          auto
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               0
select_random_game                        0
saver_type                                saver_commandline
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
reko19
« Reply #5 on: February 26, 2008, 01:50:57 pm »
turns out i used mamewah 1.62b13 instead of 1.62b13.a. apparently that version of mamewah had issues with list generation. it now works. i will try to tackle the rest tonight. I could run project 64 from the command line, so should be able to get it to work. Is wrapper required even if I use cracked version of project 64 with escape=exit?
Apologies for the double post, could I delete it, don't see an option for that.
gonzo90017
« Reply #6 on: February 27, 2008, 01:08:17 am »
I think you still need the wrapper.
reko19
« Reply #7 on: February 27, 2008, 09:43:23 am »
it is working, no wrapper is required, just get cracked exe from jcrouse site which is a great resource, many thanks.
