Main > Everything Else
Hi im back
BobbyG66:
How about bacon stuffed with bacon, then wrapped in bacon? :notworthy:
...sounds good to me!
mountain:
--- Quote from: shmokes on May 12, 2008, 10:35:33 am ---Bacon is good . . . as bacon. Wrap a fillet mignon in bacon and you end up with a $20 piece of meat that tastes like bacon. Of course, if you wanted a piece of meat that tasted like bacon you could always just buy bacon and not waste your money on an expensive steak.
Other things bacon ruins includes: hamburgers, salads, baked potatoes.
Good in BLTs, though.
:dizzy: The only food I can think of that bacon would ruin is ice cream.
Jdurg:
That's a bit close-minded with the thinking. The point of adding the bacon is not to make the meat taste only like bacon. It's like why people add salt to foods. It's not to make the food taste like salt. It's to enhance the natural flavors of the food. The idea of wrapping bacon around a steak is to add the fat and smoked flavor which bacon provides IN ADDITION to the high level of flavor that the meat already provides.
If you have a $20 steak that you wrap in bacon, and all it tastes like is bacon, then I'm sorry, but you have no clue how to cook a steak.
Bacon mixed with certain shellfish is done because shellfish really don't have a lot of inherent fat to them so by wrapping bacon around it, or mixing with bacon, you can add fat to the fish which prevents it from drying out and getting rubbery.
Like salt, bacon has to be used moderately for it to provide the flavor enhancement you seek. Too much, and like salt, the food gets ruined. If you wrap so much bacon around your steaks that all you taste is bacon, then you've done the equivalent of putting half a pound of salt on your food. This all makes sense because bacon is pretty much just fat and salt.
Once again, the point of wrapping foods in bacon while cooking is not to make them taste like bacon. It's to enhance the natural flavor of the food, add a layer of protection for the juices inside the food, and add an aroma and enhancement due to the addition of a flavorful food.
shmokes:
I've never wrapped bacon around a steak. I've only had it that way when I've ordered a fillet from a nice restaurant. And if you have a nice piece of meat, you don't need to add fat to it, nor bacon flavor. People also, quite regularly, melt butter on their steaks while they cook. I generally think this is a bad idea as well (though not as bad an idea as wrapping it in bacon, since at least butter doesn't have an overpowering flavor).
CheffoJeffo:
--- Quote from: Jdurg on May 12, 2008, 12:45:10 pm ---That's a bit close-minded with the thinking. The point of adding the bacon is not to make the meat taste only like bacon. It's like why people add salt to foods. It's not to make the food taste like salt. It's to enhance the natural flavors of the food. The idea of wrapping bacon around a steak is to add the fat and smoked flavor which bacon provides IN ADDITION to the high level of flavor that the meat already provides.
While I agree with most of what jdurg saying, there is a reason (well, actually two) that bacon is commonly used with filet mignon and not other cuts. One reason is because filet mignon is inherently LESS flavourful than other cuts (which is the same reason why it is fairly common to serve filet with a sauce). The other reason is, as jdurg points out, to provide additional fat content to keep things juicy.
Filet needs to be cooked very quickly and never, ever, ever beyond medium rare.
When cooked properly, as jdurg points out, the filet will not be overwhelmed by the bacon.
If you don't like to eat bloody beef, order a ribeye instead of filet mignon.
EDIT: I should mention that I never willingly order filet mignon -- I only ever eat it at weddings or other fixed-menu gatherings. Beef is a wonderful food (I was raised in cattle country) and there are so many tasty cuts available that it doesn't make sense to purposefully order an expensive cut that doesn't explode with natural flavour.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
