Author Topic: I got my Suzos! :D  (Read 2146 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
I got my Suzos! :D
« on: February 22, 2008, 12:53:21 pm »
I still have to build the box, hack the pad, buy the buttons, etc, but, since this will be my new panel, I have time and patience. So, I had not tried the sticks yet with a good shmup or any other game with which precission is the key, but I guess they will perform even better than my currect T-stick. The throw is really impessive, very very short and the strenght to move the stick is slightly lighter than that of the T-stick. What's really great is that the stick stays very firmly in the center until you push it, so it doesn't swing at all (a problem that is present in my T-stick). I find this stick a little longer but I plan on installing it from beneath a 19mm mdf board, which will make it shorter. I don't know, however, how I will fix the problem of the visible hole (see the pic), since the stick is conceived to be installed on iron or any other thin material. Anyway, take a look and see how this stick looks and works. What could be better than a video to show you how they feel....?
[youtube]oPUTQaNZtrc[/youtube]
« Last Edit: February 22, 2008, 12:57:12 pm by Stormrider »
Level42
Re: I got my Suzos! :D
« Reply #1 on: February 22, 2008, 02:32:16 pm »
A Suzo stick is a joy forever !
Dutch pride :)
There's only one better stick and that's the Suzo Inductive.
Enjoy !
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #2 on: February 22, 2008, 04:57:15 pm »
http://i59.photobucket.com/albums/g308/k-kowal/Custom%20Arcade%20Stick/seria%20III/Shinden-01.jpg
http://i59.photobucket.com/albums/g308/k-kowal/Custom%20Arcade%20Stick/seria%20III/Shinden-02.jpg
http://i59.photobucket.com/albums/g308/k-kowal/Custom%20Arcade%20Stick/seria%20III/Shinden-03.jpg
http://i59.photobucket.com/albums/g308/k-kowal/Custom%20Arcade%20Stick/seria%20III/Shinden-04.jpg
wood 4mm + metal panel 2mm I use washer from crap KC-04:P
originally you need metal panel with hole about diameter 45mm.
but I do not like how joystick gets up high.
I command second way from your drawing add only new big washer from iL Eurojostick or Compact joystick. You can alone make new washer from CD box.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #3 on: February 22, 2008, 06:14:04 pm »
It's not difficult to fit them to wood panels. Route it out to amout 3mm thick, then use a hole saw to cut a perfect round hole for that recess. They are incredibly sturdy sticks and have survived longer over the years in British arcades than any of those 'long-throw' sticks!
Stormrider
« Reply #4 on: February 23, 2008, 06:47:42 am »
I love your panel Kowal. That's more or less what I've planed for mine. I don't want to use artwork, but a textured surface like the one you used. What is it, paint or any kind of textured vinyl? I see you're using a replacement shaft. Unfortunatelly I have not access to that here in Europe. Anyway I don't like the idea of disassembling the stick so I think I'll use a hand-made washer cut in the half which I'll install glueing the two pieces one the stick is installed. If I'm carefull the result will be acceptable.
kowal
  • Suzo 4ever
« Reply #5 on: February 23, 2008, 07:54:53 am »
it is metal panel painted with "hammer-paint"
better take out stick before add washer
http://forum.arcadecontrols.com/index.php?topic=53835.0
Stormrider
« Reply #6 on: February 23, 2008, 09:30:32 am »
I've disassembled one of my sticks, but I cannot remove the e-clip. Reading the post that you kindly linked I've found out that you need a special tool for this kind of clip. I'm a little afraid of breaking it. I think that, at the moment, I'm going to try the other way: install the stick and then the washer in two pieces. If I see that the result suck then I'll try removing the clip. Thanx a lot for the links.
kowal
  • Suzo 4ever
« Reply #7 on: February 23, 2008, 12:26:52 pm »
use mini scissors (to nails)- carefully
yes suzo clip is crap
I use normal E - clip how in joysticks iL
Stormrider
« Reply #8 on: February 26, 2008, 08:22:07 am »
I took the stick to a hardware store and they were so kind to release the damned clip for me. They had the right tool and I didn't had to buy it. :) Now I'm waiting for Industrias Lorenzo to answer. I'd like to know if they can send some washers. If they don't sell these parts separatelly, I'll take it from a crappy mando compacto (Happ's super joystick) of a friend of mine.
Level42
« Reply #9 on: February 26, 2008, 03:48:15 pm »
You need this ?
Arcadeshop.com, so a search for "Joystick disc" $2,-
Stormrider
« Reply #10 on: February 26, 2008, 04:28:49 pm »
hehe, thanx for the tip, but it would be really funny pay 2$ for the 'disc' and 100$ or more for the shipping to Spain :D No problem: as I said a friend of mine is gonna sacrifice one of his old sticks for this.
PD: taking a look at the picture... I want that texture for the surface of my CP! There must be some kind of paing with texture effect... I guess.
Stormrider
« Reply #11 on: February 27, 2008, 07:58:09 am »
These are the plans for my panel. I don't know if I will use smaller buttons for coin, start and service functions, if I find models which look and feel right. I will use 19mm DM, and 16mm DM for the top panel. The base will be 2mm iron.
Level42
« Reply #12 on: February 27, 2008, 11:43:11 am »
Yeah, I'm quite sure that sending an envelope with 2 or 3 of these (that weigh close to nothing) will cost mre than about 3 bucks in shipping....anway you've already found a better solution....
kowal
  • Suzo 4ever
« Reply #13 on: February 27, 2008, 12:09:49 pm »
I wanted to buy in IL joysticks. I asked about cost 10 and 100 q. Price was 1,5 larger x than on Happ with tax 2x higher. This completely idiotic!
 HAPP buys from iL->Suzo buys from HAPP and it  went out me 2x cheap. these joysticks 2x surrounded world! and are 2x cheaper - This completely idiotic!
Paul Olson
  • Last login:Today at 07:18:52 am
    • Paul's Arcade
« Reply #14 on: February 27, 2008, 07:56:04 pm »
Can someone who has an inductive stick give a mini review of it here? I found one on ebay, but I have not mounted it yet. I am really not even sure how to hook it up. I can search later if no one responds, but I thought I would ask since it was mentioned in this thread.
Thanks,
Paul
kowal
  • Suzo 4ever
« Reply #15 on: February 28, 2008, 01:19:50 am »
Paul Olson
    • Paul's Arcade
« Reply #16 on: February 28, 2008, 02:30:11 pm »
Thanks kowal, that helped a lot. Now I just need to find time to mount it :banghead:
