Main > Everything Else
What DVD format is best for archiving purposes?
paigeoliver:
The hard drive solution likely wouldn't cost ANY money at all. If you quickly ask around amongst any techie friends and co-workers you can usually EASILY get a whole bunch of older hard drives for nothing. They have no value at all.
ark_ader:
--- Quote from: paigeoliver on February 28, 2008, 04:34:59 am ---The hard drive solution likely wouldn't cost ANY money at all. If you quickly ask around amongst any techie friends and co-workers you can usually EASILY get a whole bunch of older hard drives for nothing. They have no value at all.
Especially now as sizes are getting bigger, those 120GB drives are super cheap. Vac seal those drives afterwards and place them in room temperature storage. Super idea for cheap storage.
I thought of what you said was rather apt considering the the video of the xbox drive domino stunt i just watched. So much better than using DVDs.
ChadTower:
Keep in mind Grasshopper needs about 5-10gb of storage, not 120gb. Paige is right, free drives of that size are certainly possible to obtain. A USB enclosure and 3-4 of those will do nicely. I got my USB enclosure for about $20 shipped, works well, and it takes 2 minutes to swap a drive into it.
SavannahLion:
--- Quote from: ChadTower on February 29, 2008, 08:54:26 am ---I got my USB enclosure for about $20 shipped, works well, and it takes 2 minutes to swap a drive into it.
I'm usually far too lazy to do even that. I went out and bought a 2xPATA to USB adapter sans power and use that instead. At the time it cost me about $25 or so. Now you can find SATA+PATA to USB adapters with a suitable power supply for about that much.
ark_ader:
Another option is to utilise a pull out caddy system. I have seen them go for as little as $20 and the cages were much lower. Great for plug and play. Ideal for those SCSI drives floating around with that capacity.
http://cgi.ebay.com/Removable-Mobile-Rack-Hard-Drive-HDD-IDE-Hot-Swap-2-Fan_W0QQitemZ180218115254QQihZ008QQcategoryZ64463QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
And those hard drives?
That would be a cheap solution!
Navigation
[0] Message Index
[*] Previous page
Go to full version
