Main > Everything Else
What DVD format is best for archiving purposes?
SavannahLion:
--- Quote from: Peale on February 16, 2008, 06:50:12 pm ---
--- Quote from: ChadTower on February 16, 2008, 01:17:00 pm ---
A hard drive may not be all that more reliable in the long run.
That's why I'm suggesting several smaller drives with redundant backups.
Different brands and/or batches while you're at it.
As for DVD's, is DVD Identifier still the usual tool of choice to identifying your discs?
patrickl:
I have to concur with Peale. Optical media are pretty unreliable. I use hardisks in trays that swap out. Now and then I even replace my off site copy so i'm protected in case of fire or burglary.
I do make backups on DVD's now and then too (and CD's before), but sometimes they become unreadable pretty quickly.
shmokes:
Have you considered an online storage option? Get with reputable company and you know that your data will be off-site, with multiple levels of failsafes built-in. I don't know what something like that costs, but considering the amount of space you get with a free Gmail account, I can't imagine online storage can be too terribly expensive. It would also give you the side-benefit of having access to that information no matter where you were.
patrickl:
Yes, on-line storage is a good idea too. Especially for stuff that doesn't change that often.
If you need to backup a lot every time then it might be a problem since uploading files can be quite slow and there might be a traffic limit on your internet connection.
Dexter:
I built a PC for my dad at christmas wit a raid 1 setup. A good solution for redundancy if one drive fails, improves performance too.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
