Main > Main Forum
Key Switch
brock.sampson:
--- Quote from: mountain on February 15, 2008, 03:45:01 pm ---
--- Quote from: brock.sampson on February 15, 2008, 02:12:34 pm ---I would think this should work. http://www.amazon.com/Key-Switch-with-2-Keys/dp/B0002BA3PE. I have some toggle switches mounted inside the coin door where the test switches were originally to do the same thing.
I have this exact switch. It will work but it will not fit in a 3/4" hole. You might be able to modify a button and drop it in the button casing.
I thought he was going through 3/4" mdf not a 3/4" hole, am I not reading the original correctly?
somunny:
Well, here it is:
It's kind of a beast. Momentary, two position switch. Won't work on a 3/4" deep surface, though. 1/2", maybe 5/8".
QuarterJunkie:
After reading the posts about already having key access from the coin door, a switch mounted inside does seem the more logical choice. Thanks!!
mountain:
--- Quote from: brock.sampson on February 15, 2008, 04:41:11 pm ---
No, I misread it.
--- Quote from: shardian on February 15, 2008, 03:46:42 pm ---You can pick up a cheap keyed ignition switch at Autozone/Advance Auto.
Your coin door already has a keyed entry though, so just put a toggle inside there.
Good call.
Turnarcades:
I've not got much experience with these types of switches.
Could one of these be used in theory to replicate the key-turn switches that replaced start buttons on cabinets like Outrunners?
I'm about to start work on a driving cabinet and this would be a nice touch.
