Main > Main Forum
Ultrastik template
Pages: << < (4/4)
Ginsu Victim:
Do you have the sticks now?
Franco B:
FYI the U360 has the same mounting plate as the Sanwa JLW. I have attached the JLW mouting plate dimensions from arcadeshop.de
Ginsu Victim:
Or if you have the sticks already, you can easily remove the mouting plate and use it as a template.
cmoses:
I do have the joysticks so I can use the mounting plate as a template.  Thanks also for the JLW mounting plate template.
The one thing that I don't have and is not shown is the area that needs to be cut out for a top mount application.  I can use the template or the joystick mount plate to mark the area, but when top mounting there is a section that needs to be removed for the joystick to fit through.  It is not the full size of the mounting plate.  Does anyone have a template that shows the area that needs to be removed?  Or does someone know what size that is?
Franco B:
cmoses, I'm just doing a JLF top mount tutorial at the moment which you can apply to the JLW/U360. I should have it finished this afternoon. I'll post the pics etc in [this] thread.
Pages: << < (4/4)
Go to full version
