Main > Project Announcements
Golden Tee Mame **completed**
<< < (5/7) > >>
Nostalgia:
Go to the start menu, type in MSCONFIG. Then go to the startup tab, and uncheck all the boxes with the crap you dont need. MAKE SURE WINDOWS DEFENDER IS DISABLED. That program is a huge memory hog. Turning off everything you dont need should help a ton. Make sure Aero and the sidebar is off also.
golfboyusa:
I have come to the conclusion that Vista sucks. I am in the process of loading XP. I'll let you guys know what happens...... :angry:
Franco B:
Awesome  :applaud:
The next time I build an upright im going to look at this design for inspiration  :applaud:
golfboyusa:
I have performed an exorcism and removed the vile beast Vista from my computer. I am now running XP and all my problems have been solved! Pin Mame now runs like a champ as well...... :cheers:
I highly reccomend that future MAME'rs stay away from Vista unless the computer is a real powerhouse......
Avrus:
I've had no problems with Vista since RC1.
If the hardware is brand specific, you're likely not going to do well with an O/S other than what it's designed for.  If it's a build your own, stability tends to be find with whatever O/S.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
