Author Topic: Shortest Buttons?  (Read 1402 times)
Bender
Shortest Buttons?
« on: February 07, 2008, 12:08:35 am »
Anybody know if there are push buttons made that are full size from the top but the housing is only 3/4 or less deep or does anybody have any ideas on how to make one
I'm building a cab with a rotating control panel and I want to have a couple of pinball buttons on the sides but I only have the 3/4 width of the side of the cab (anything longer would prevent the cp from rotating)
thanks!
protokatie
Re: Shortest Buttons?
« Reply #1 on: February 07, 2008, 12:12:18 am »
check out the "light blue buttons" thread:
http://forum.arcadecontrols.com/index.php?topic=75445.0
and scroll down a bit to the sanwa buttons, there is a pic for buttons that arent very "deep", but they are meant for mounting in a metal control panel, so you may need to mod them.
Edited: No link for getting sanwa buttons, Im sure someone here can help you, or you can google.
Bender
« Reply #2 on: February 07, 2008, 12:17:16 am »
Thanks protokatie,
anybody know how deep those sanwa buttons are including the terminals?
Daniel B.
  • Last login:April 29, 2024, 11:30:31 pm
  • Lightgun and Point Blank enthusiast
« Reply #3 on: February 07, 2008, 12:24:17 am »
i would have to guess 25 - 35 mm or so. They are about as thin as you are going to get.
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
Daniel B.
« Reply #4 on: February 07, 2008, 12:24:59 am »
double
Bender
« Reply #5 on: February 07, 2008, 12:43:27 am »
http://www.coinopexpress.com/products/parts/push_button/33mm_Round_Momentary_Contact_Push_Button_with_Clipper_2295.html
I found these but they have a minimum order of 960 :banghead:
I only need like 4 or 6
these would work especially if I bent the contacts down
they may only be 13mm deep
I'll keep lookin'
I still think there may be a way to make some too
protokatie
« Reply #6 on: February 07, 2008, 12:47:02 am »
Take a happ button, remove the spring, and cut it down to near the ring. Super glue in a leaf spring and jerry rig a happs style switch in there... Most of a Happs (or similar) button is shaft and spring... If you are willing to sacrafice a button, im sure you will find a way to make them really short. There is a limit tho, you need some level of decernable travel for the button...
Kajoq
  • Last login:May 07, 2024, 11:32:33 pm
« Reply #7 on: February 07, 2008, 10:58:27 am »
Bender - go check out http://www.lizardlick.com
They have a great selection of Sanwa and Seimitsu parts, and ship super fast.  I've ordered a ton of parts from them.
The sanwa buttons aren't going to be as thin as that button you linked because they have external microswitches (that are a lot nicer than the ones on that button)  I can't find a tape/ruler anywhere handy, but the sanwa screw-in i have in front of me is probably just a touch over 1" tall, going from top to bottom of the terminals.
If i'm understanding your clearance issue correctly, I think you could make the sanwas work if you got screw ins.  Route out a hole a little larger than the button and mount it inside the hole
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
« Reply #8 on: February 07, 2008, 02:51:26 pm »
These are some available in the UK...
http://www.gremlinsolutions.co.uk/ordersanwapushbuttons.php...
Might give you a few model numbers to google for US sources...
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #9 on: February 08, 2008, 01:18:12 pm »
I can get these for you from happ & there is no min. order
dm
http://happcontrols.com/pushbuttons/601200xx.htm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
