Author Topic: magstik balltop removal...  (Read 1065 times)
fixedpigs
  • Last login:June 05, 2022, 04:56:10 pm
  • warning: drew can't handle my avatar...
« on: February 05, 2008, 09:09:14 pm »
i want to take off my magstik's balltop...but it doesn't seem to want to come off...
i put a wrench on the 'nut' part of the shaft and went to turn the ball counter-clockwise...i heard a slight noise and stopped...
are they epoxied onto the shaft or use red loctite or something...?
has anyone been successful in removing the balltop from a magstik...?
thanks in advance...
somunny
  • Last login:September 05, 2018, 02:22:25 pm
  • Is it hot in here?
Re: magstik balltop removal...
« Reply #1 on: February 05, 2008, 09:41:47 pm »
I wanted to change the color of a mag ball top and contacted Andy at Ultimarc about it.  He said they don't come off.  I think the plastic ball is molded around a groove at the top of the shaft rendering it permanently attached.
You might be able to hack the red ball off, thread the top of the shaft and use another ball.  This wasn't something I really wanted to try myself though, so let me know how it goes.  ;)
« Last Edit: February 05, 2008, 10:21:37 pm by somunny »
fixedpigs
« Reply #2 on: February 05, 2008, 09:50:35 pm »
that's kind of lame...i wanted to mount it with the dustwasher underneath my overlay... :dunno
somunny
« Reply #3 on: February 05, 2008, 10:15:29 pm »
I think I misunderstood you.  ???  Do you want to remove the ball from the stick or the whole thing from the base?  If it's the latter, it can be done.  There should be an exploded diagram of the stick on ultimarc's site.  Have you checked it out?
EDIT:  Here's the link to the exploded view:
http://www.ultimarc.com/controldiags.html
You should be able to spin that nut right off.  It's a locknut, right?  The plastic lined type?
Forget it.  After looking at mine, I see that there's no way to do what you want to do.
« Last Edit: February 05, 2008, 10:24:26 pm by somunny »
fixedpigs
« Reply #4 on: February 05, 2008, 10:22:42 pm »
i want to remove the ball from the shaft...i already have the shaft apart from the base...
( _)  <---- ball top
----  <---- dust washer
 =   <--- 'nut'
  |   <---- shaft
my plexi would have to go in between the balltop and the dustwasher...can't happen if the balltop doesn't come off... :(
somunny
« Reply #5 on: February 05, 2008, 10:25:38 pm »
Yeah, sorry 'bout that.  :-\
NoOne=NBA=
« Reply #6 on: February 06, 2008, 09:36:09 am »
I think the balltops are molded onto the shaft.
The bat tops for the T-stik were definitely done this way because I did actually remove one of those.
All you need to do is cut a slit in the dustwashers.
Then you can slide them into place wherever you want.
The slit will be hidden by the CP.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #7 on: February 06, 2008, 03:32:23 pm »
The balls are Lockited on, because you need to grip the ball and turn both ways in the process of switching 4-8 way. But theres no reason why we could not supply a shaft with the ball not attached.
Andy
somunny
« Reply #8 on: February 06, 2008, 08:03:04 pm »
Andy
That's good to know as I'd like to put a yellow ball on one of mine.
