May 09, 2024, 08:43:21 am
I think MaximRecoil hit it on the head in your last thread ...
That's not a Dynamo cabinet—it's an Atari cabinet (Centipede?). That Dynamo (or Dynamo-style) "cut-corner" control panel on it is obviously not original to the cabinet.
Were all ATARI cabs the same, except for the side art/marquees, etc? I know a Tempest cab is quite different-looking
No. Only Centipede, Dig Dug and Kangaroo shared that particular design, and even then there's small variances, like the type of coin door.
I believe that Centipede was also the only one that was "undercut" beneath the control panel; or more accurately, "overcut" above the CP (the Centipede is "fatter" on the sides above the CP). For example:Also, I think the other Atari cabinets of that general shape, such as Dig Dug, had a notch cut from the lower rear corners, while Centipede didn't.
