Main > Main Forum
How to set IPAC to use ESC/TAB key?
HeadRusch:
....ok....
I think I "get it" now......I'll go try this again.....
I guess this info will solve every one of my problems...except for the rather stupid problem of not being able to get my tulip-tipped HAPPS joystick buttons to work. I've got the microswitches actuating and everything.......two tulip-tipped sticks, and two buttons that wont work. I'll check em out with a voltmeter to make sure they're working ok.
HeadRusch:
Ok...I went back and tried it...you're right, I was going about it all wrong :)
Thanks everyone for taking the time to explain it to me.
However, I've still got some problems.
Player 3 and 4 have tulip-button topped HAPPS sticks. Neither of the buttons is working.
The microswitches for the top-buttons are clicking, and they are wired correctly...but the IPAC wont register them. It doesn't see any signal. This is also the case on the momentary switch buttons that I'm trying to assign to ESC and TAB (Wired into Player 4's 7 and 8 button slots).
Player 3 button 5 (button in the stick), not working...
Player 4, button 5 (button in the stick) also...not working.
Player 4 button 7 and 8, both momentary-switch buttons from radioshack......neither will register on the IPAC.
I've mailed Andy to see if he's seen this before. Tomorrow before I "nail down" the top of the panel to the control box, I'll test the switches with the voltmeter just to make sure its not them.
