Main > Main Forum
I found this
anthony691:
--- Quote from: Izdawiz on May 18, 2003, 08:54:37 pm ---Yes of course an inerframe!!! That sounds like a good idea. Cuz the wood is awfully thin. I wasnt sure if I could use it, and it would of been a waste to throw it away. I have a guide from www.cybertechdesign.net but no framing guide can some one send a good link? ;D
You can usaully just make frames and stuff up. I had a cab with the front kicked in; and we repaired it, but in the process it's structural integrity was comprimized. We made up some Cross-Bars from 2x4s and it was fine. If the frame goes into the corners; it will make the joints easy :)
OzStick:
Yes, by all means use it as it's free!!
15/32" is 12mm in my language. I threw together a smallish upright for my kids using 12mm MDF and as already suggested, if you use a few braces connecting the side panels at strategic points it will be plenty strong enough. You'll also have the added bonus of a much lighter cabinet!
Don't worry about not having plans for braces, just use a couple of offcuts that are at least 6" wide and attach them to the side panels using angle brackets.
Just make sure you make a nice solid frame at the base of the cabinet as this will hold it all together!!
Sasquatch!:
--- Quote from: OzStick on May 19, 2003, 05:02:26 am ---15/32" is 12mm in my language.
Will you just smile and give me a vegemite sandwich?
</LandDownUnder> ;)
Izdawiz:
Great Help here I knew I came to the right place I will begin work in 3 weeks lets see how it turns out. 3 more weeks and im outa school. thanks again fellas
Sshado:
Scott's Unicade has a great write up on building a frame, here is the link:
Scott's Unicade
Sshado
