Author Topic: Konami GT Wiring question  (Read 1308 times)
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
« on: February 01, 2008, 12:29:20 am »
I just received a Konami GT control panel that has the optical encoder still attached. I am planning on using it in a MAME cab but I can't tell what the connections are for the Encoder Board  (they don't appear to be labeled).
Anyone have any thoughts?
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Konami GT Wiring question
« Reply #1 on: February 01, 2008, 04:03:53 am »
I don't have the circuit diagram to hand right now.... but can't you just trace the tracks on circuit board to see what they are and where they go to???
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
milhouse
« Reply #2 on: February 01, 2008, 07:57:32 am »
I tried but can't tell.  '
Here is a (bad) photo in case that helps anyone.
Fozzy The Bear
« Reply #3 on: February 01, 2008, 09:00:20 am »
I can't trace them from that photo, try removing that paper sticker so you can see where the tracks are. The only one I can see.... It looks like the ground is the one at the top of the connector.
Best Regards,
« Last Edit: February 01, 2008, 09:03:04 am by Fozzy The Bear »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: February 01, 2008, 09:22:52 am »
This took me a while to find ... my search-fu powers are weakening:
http://www.arcadeuk.com/pinouts/KonamiGT.htm
Working: Not Enough
Projects: Too Many
Progress: None
milhouse
« Reply #5 on: February 01, 2008, 09:46:03 am »
I found that too - but I couldn't tell if that was the connection off the main PCB or onto the encoder.  I don't mind experimenting but I don't want to blow it out before I even get started.
Thanks.
Level42
« Reply #6 on: February 01, 2008, 11:05:32 am »
Maybe the pics on my Konami GT thread could be of help ?
http://forum.arcadecontrols.com/index.php?topic=69991.0
I seem to remember that the steering wheel was connected to that extra (side) PCB, but not sure....
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: February 04, 2008, 05:12:30 pm »
Interesting that the encoder has 6 pins.  It's hard to tell from the pic (backlighting can sometimes help tracing), but it looks like only 4 of the pins are used?  If numbered starting at top, 1, 3, 4, 5 look wired, while 2 and 6 look not connected.  With that, I would guess 1 and 5 are ground and power (or vice versa).
Robin
Knowledge is Power
milhouse
« Reply #8 on: February 04, 2008, 05:59:12 pm »
Got it working.  Two of the pins aren't connected.  The text from the above link is correct, so now I have a working 360 wheel.  Now I just need some potentiometer pedals.
Thanks for everyone's help.
