Main > Everything Else
Best solar powered hack ever........
boykster:
--- Quote from: Peale on January 29, 2008, 01:09:41 pm ---
--- Quote from: patrickl on January 28, 2008, 07:59:17 pm ---What's going to happen when there is a lot of sun or just a little bit? Don't you need some sort of voltage correction circuitry (both up and down)?
More for when the light is less, I would think. Solar cells are kind of self-limiting.
Yep, and since it's being used to power/charge via USB and is relying on the target device for voltage regulation, I'll bet when the voltage drops below a certain threshhold, the charging is shut down. My phone is very particular about the volt/amp rating of a USB port...some ports it works fine with, some it doesn't, and when it doesn't work, it just wont' charge
patrickl:
--- Quote from: boykster on January 29, 2008, 02:49:24 pm ---...
Well I'm wondering since I have used battery powered chargers and they do tend to draw power from the phone when the power of the charger runs low. When the battery in the charger has a lower voltage than the battery in the phone the phone would actually "charge" the charger. I would end up with a completely drained charger and phone in the morning.
SirPeale:
I'm wondering if the voltage could be boosted with a transistor, like with the Joule Thief.
Recently I've started looking into alternative lighting for emergency and recreational purposes (ie camping).
I'll start a new thread with some of my ideas.
Navigation
[0] Message Index
[*] Previous page
Go to full version
