Author Topic: Painting Tips?!  (Read 1379 times)
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
Painting Tips?!
« on: January 27, 2008, 04:26:03 pm »
Howdy all,
I wanted to start a thread where people can post their tips for painting their cab to get the best finish possible.
I took my ROS to my cabinet today and got all the shiny black paint off so I can start fresh.  I did find out my cab used to be an NBA SHowtime cab as all the side art and such was still there but had been painted over...
Anyway, what are some Best Practice things you'd recommend?  Maybe we could get a sticky topic or something about this.
Some possible things to discuss:
Primer.  Latex vs Oil?  Does it really matter?
Paint.  Latex vs Oil?  Does it really matter?
How many coats or primer and how many of paint?
What do you do between coats to get the smoothest finish.
Do you put a top layer of Poly or something similar to lock everything in?
I'm looking for advice since once I get the holes patch and such, painting is my next step.
Thanks.
« Last Edit: January 27, 2008, 04:35:32 pm by kelemvor »
Jdurg
Re: Painting Tips?!
« Reply #1 on: January 27, 2008, 05:28:41 pm »
Well, with the primer it all depends on what you're going to use for paint.  You absolutely can NOT use a latex based primer and then use an oil-based paint on top.  It's just not compatible and you'll have nasty results if you do.
Many years ago, oil based was always the no-brainer if you wanted a durable, smooth finish paint.  Thankfully, latex technology has gotten so much better these days that you can paint a cabinet with latex and have it be just as durable as with oil based.
Latex paints tend to dry quicker and have far less nasty fumes than oil based paints.  Clean up is also a big plus since latex paints can typically be cleaned with water.
The biggest thing to remember regardless of which type you use is the environment.  You do NOT want to paint in a dusty area, nor do you want to paint in an area that has poor ventilation.  Good ventilation allows even drying/curing of the paint and dust free ensures that no dust particles settle on your wet paint job.
Before you paint, it's a good idea to thoroughly sand your cabinet with a mid-grade sand paper to create a surface that the paint can adhere to.  When done with that sanding, use a tack cloth to make sure you have removed any dust left on there.
Whether it's primer or the final paint, multiple thin coats are far better than one thick and sloppy single coat.  I personally would put on two or three coats of primer, sanding in between each coat to ensure a smooth finish.  If after two coats of primer you have sanded it smooth and not sanded through to the surface below, then you can apply thin coats of paint, sanding in between, until you get the color saturation you're looking for.
Always sand lightly in between each coat of paint.  This helps ensure a smoother overall finish.
A final clear coat can help seal everything in and allow you to buff it out and get a great gloss finish.  However, read the paint can very carefully.  Make sure you get a paint that WON'T yellow over time as this will make any paint job you've done underneath look like crap.  And, if you are putting artwork on the cabinet, MAKE SURE THE PAINT IS COMPATIBLE!!!!!!!!  Water based clearcoats are typically more compatible than the other solvent based clears, but always double check this.  Nothing worse then spending hundreds of dollars on great artwork and weeks on painting and sanding only to ruin it in five seconds by putting on an incompatible clear coat.
One more thing is to allow ample drying time between coats.  If you paint one coat on the weekend and don't get back to it until the next weekend, that's great.  This allows any solvents in the paint to gas out and cure so that you don't get odd bubbling later on down the line.  This is especially important after you adhere the artwork to the cabinet.  Let it cure and degas for a few weeks just to play it safe before you clear coat it.
The biggest advice is to take it slow.  Don't rush it.  This will be the most noticeable part of your cab so it's important to take it slow and do it right.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
kelemvor
Re: Painting Tips?!
« Reply #2 on: January 27, 2008, 11:00:05 pm »
Thought of one thing I forgot to ask...
How do you get the best (smoothest, shiniest, etc) finish as far as brush, roller, spray gun, etc?  I've got plenty of experience painting walls but that's about it. :)
Jdurg
Re: Painting Tips?!
« Reply #3 on: January 28, 2008, 08:50:51 am »
Apparently a spray gun gives the smoothest finish, but only if you have the right humidity level, have thinned the paint out properly, and move at the right pace.
Next would be a very fine foam roller, followed by a brush.  To get the paint smooth, you need to allow the paint to come out of/off of your applicator (Brush/roller/spray gun/etc.), adhere to the surface you're painting, and level out before it dries.  This way you don't have ridges and bumps caused by the paint drying before it can level itself out.  This is also why you have to thin the paint properly.
Then, it's sand, sand, sand.  You want to sand to level off the high spots but you don't want to sand so much that you remove the entire layer of paint you just put on.  When you're done, some rubbing compound will do wonders to get rid of the final little imperfections, but it won't get rid of large bumps or "orange peel".
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
  • Last login:Yesterday at 07:54:28 pm
Re: Painting Tips?!
« Reply #4 on: January 28, 2008, 10:18:03 am »
Rubbing compound and car wax was involved in my finish.  It's all smooth and glassy now..  if you are interested you can read HERE starting at April 12, 2007 to June 11, 2007 for a VERY detailed explanation and lots of pics.
kelemvor
Re: Painting Tips?!
« Reply #5 on: January 28, 2008, 10:25:06 am »
Is it better to paint it while it's flat so things can even out and not run?  I guess I could clip it over and paint the one side to completion and then do the other side when the first side is done.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
Re: Painting Tips?!
« Reply #6 on: January 28, 2008, 10:40:47 am »
Do anything that javeryh says to do.  PERIOD.
Seriously, its amazing.
Re: Painting Tips?!
« Reply #7 on: January 28, 2008, 11:23:53 am »
Heh, thanks for the endorsement but I'm certainly no expert (although it did come out much better than I thought it would ;D).  I followed THIS GUY as close as I could to get my finish.    :cheers:
