Main > Main Forum
What do you use for complete backup's?
TimmyB:
I am using mirrored drives, two hard drives that are kept identical by a RAID controller on the motherboard. If you have a hardware failure of one drive you have a complete copy. Only expense is the extra harddrive, assuming you have a motherboard with a built in controller. Nice because it is fire and forget, don't have to flip CDs/DVDs, run backup jobs, etc.
For versioning I wam going to use Volume Shadow Copy which is built in to the Vista OS. You could also try out Beyond Compare. A GREAT utility program. You can use that to make snapshots of a folder. I also use it to sync ROMs, CHDs and other support files between my normal workstation and my arcade cabinet. The latter is a nice feature since it only copies the files that have changed.
ChadTower:
Both. You're the one who said:
--- Quote ---I don't know about you, but even with the practice of discarding older dics, those things have a nasty tendency to collect. Spindles start growing like trees on the desk. Horizontal surfaces are covered in colorful plastic quilts.
That doesn't happen when you reasonably follow accepted best practices.
SavannahLion:
--- Quote from: ChadTower on January 23, 2008, 06:59:18 pm ---Both. You're the one who said:
Naturally. You do realize, however, that I have a girlfriend that I have to appease and a seven year old that I don't?
BobA:
I use TrueImage and make a copy of my drive on another HD. Costs very little to duplicate your drive now days and gives great piece of mind when you have alot of work invested.
Havok:
I use Ghost and a second hard drive - save the image to the second drive, and that's it.
