Author Topic: mamewah video samples  (Read 1186 times)
dfg
  • Last login:March 31, 2012, 09:17:03 am
« on: January 21, 2008, 08:14:44 pm »
currently setting up mamewah for my cab. ive got all the layouts set up working and the snaps working. ive editted the ini files to read the paths for the videos and selected the same artwork #1 as the snaps but no matter wat i do the videos wont show up only the snapshots. the video are all .avi format too.
ne ideas wats the problem??
Zeppo
  • Last login:February 14, 2024, 10:26:44 am
  • Greetings Program!
Re: mamewah video samples
« Reply #1 on: January 21, 2008, 08:50:22 pm »
I had that exact problem.
Read this thread from the mamewah forums at mameworld:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=109678&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1&new=1179919041
Hope this helps.
Z
somunny
  • Last login:September 05, 2018, 02:22:25 pm
  • Is it hot in here?
« Reply #2 on: January 21, 2008, 09:57:24 pm »
So...  It's a bug in Mamewah?  Did it ever get fixed?
dfg
« Reply #3 on: January 21, 2008, 10:14:44 pm »
Hope this helps.
yes thanks heaps dude, info helped nicely. got it all workin great.   much appreciated  ;D
Zeppo
« Reply #4 on: January 22, 2008, 10:17:45 pm »
Not yet, I still have my fingers crossed.
Minwah hasn't put out a newer version yet.
Z
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #5 on: January 23, 2008, 11:49:15 am »
As long as you've got all your codecs installed (use something like the SLD codec pack), startup, shutdown and preview videos work fine. Be sure to edit the ini to make sure that the preview replaces the correct image number.
