Main > Software Forum
NullDC problems
unclet:
So if I redo my dc-boot and dc-flash files then this should work?
How do you set the date/time?
The NullDC readme files do not even mention what the default key mappings are for anything.
SGT:
Default keyboard attached below is user configurable. Just use up, down, left, and right with the A Button (V) to set the date and time. As Hoopz mentioned you need the English version of the bios.
Hoopz:
I've found that the Nulldc docs are lacking in general guidance. And don't post questions in their forums also. They aren't very tolerant with most newbie questions.
There's a whole process of selecting what plugins to use, then configuring them etc.
Launch the program, go to "Options", then "Select Plugins". Find what you want to use for inputs under "Maple (Inputs/Saves) Plugins:"
Once yo do that, go to "Options', then "Maple", then port A (probably) and setup your controls.
Here's a sample of the controls from one of the mods at the GameEx forum:
http://www.gameex.info/forums/index.php?act=attach&type=post&id=2961
unclet:
--- Quote ---Default keyboard attached below is user configurable. Just use up, down, left, and right with the A Button (V) to set the date and time. As Hoopz mentioned you need the English version of the bios.
I do believe I am using the wrong bios files. I will fix that .....thanks again for the advice.
--- Quote ---Launch the program, go to "Options", then "Select Plugins". Find what you want to use for inputs under "Maple (Inputs/Saves) Plugins:"
Problem was I never selected anything for the "Maple" options so that is why the Port A stuff was never allowed to be selected.
I am going to use the "nullDC Controller [WinHook]" choice but I am not sure whether I need to select nullDC VMU as the expansion slots ..... what do you think ... should I leave the 2 expansion slots under PortA to be "None" or choose "nullDc VMU"?
(EDIT)
Everything seems to be working now ....... and I guess I would need to select an expansion slot "nullDc VMU" if I want my game play to be stored ..... correct?
I now can go read that other post explaining how nullDC can be started from the command line in fullscreen mode now ...... thanks for all the help.
(EDIT)
northerngames:
just started trying to use this and I am still stuck like the origanal post where it is missong a syscalls.bin and IP.bin
I also did the same as the first post by unclet.
I tried plugin setting by SGT.
and all my maple setting are greyed out for the port A B C etc.
I tried chank and it just freeze's upon start-up and not working for me either.
on a p4 3.2gig with HT onboard sound/video 512MB ram 64mb shared with the onboard graffix xp sp2 OS
