Main > Software Forum
NullDC problems
Pages: << < (3/3)
unclet:
Did you install the lastest DirectX as wellk as the Microsoft Visual C++ runtimes which the Readme.txtfile requires?   Just a guess .....
northerngames:
I switched from this troubled pc and installed it on my cab one and it fired right up.
only problem now is when I select the maple option I can adjust the controller setup to work with the arcade controls but the memory save part is not working I can select port A and B but the following box for them is greyed out.
so now I need to figure out how to get the save part working.
Hoopz:
--- Quote from: northerngames on January 26, 2008, 02:04:07 pm ---I switched from this troubled pc and installed it on my cab one and it fired right up.
Go into Options -> Select Plugins and there is a drop down arrow underneath the Maple plugin that you already selected.  Hit the down arrow and select nullDC (VMU).  It's the only option there so its easy to select.  :)
That should do it for you.
northerngames:
I do have it set for that already and it still does not work.
I checked the beta v1.0 folder and it contains 2 vmu files that my v1.6 does not have so I even tried to copy them and paste them into the v1.6 folder and hoped it worked but it did not.
also on the V1.0 beta it had a self installer where my v1.6 was a extractor type perhaps I need the V1.6 installer set-up instead of just extracting the files.
if that is the case where can I find that at?
it seems to me I am missing the files but dont understand why they were not included like the v1.0 beta lol.
EDIT: I got whatever I throw at it working but I may need more pc horsepower becuase it is a little to choppy to enjoy still.
Pages: << < (3/3)
Go to full version
