Author Topic: 1P buttons  (Read 1089 times)
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
1P buttons
« on: January 19, 2008, 06:05:23 pm »
Anyone know of 1 and 2 player buttons that are similar to happs in which the paint doesn't come off in 5 seconds???
Kajoq
  • Last login:May 07, 2024, 11:32:33 pm
Re: 1P buttons
« Reply #1 on: January 19, 2008, 06:14:47 pm »
While I haven't ever used them myself,  Lizardlick has yenox buttons very similar to the HAPP ones available.  I don't know if their paint is any better, but you could send Chad an email and ask him
pacmandude
  • Last login:April 17, 2008, 01:45:05 pm
Re: 1P buttons
« Reply #2 on: January 19, 2008, 09:41:30 pm »
Although I haven't had a chance to heavily use the Happ buttons you are referring to, they look very well made. I can't peel/rub off the paint with my fingernail or anything. Perhaps you got stuck with a dud?
ideft
Re: 1P buttons
« Reply #3 on: January 20, 2008, 04:59:19 pm »
Maybe, because the paint on mine started to flake off in a month.  What was left I just rubbed off.
  • Last login:October 20, 2023, 11:39:06 pm
Re: 1P buttons
« Reply #4 on: January 20, 2008, 06:44:04 pm »
Have you considered purchasing clear pushbuttons and then inserting the player 1, etc inserts?
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=302
That way it cannot rub off since the graphic is on the inside.
~ DeLuSioNaL
Green Giant
Re: 1P buttons
« Reply #5 on: January 21, 2008, 12:28:50 am »
I picked up player 1 pushbuttons from groovygamegear.  I think they might be happ, but they are still going strong with all the paint.
Toxic Arcade, my first build
protokatie
Re: 1P buttons
« Reply #6 on: January 21, 2008, 02:07:52 am »
The buttons I got from andi that have the p1 and p2 "paint" on them I am presuming are origonally from happ. I tried to use my fingernail to remove the decal, but other than a slight "noise" and the obvious nature of their being a different material on the surface of the plastic, I couldnt removed any of the "paint".  Maybe the person who posted this thread got a bad batch, or plays games WAY too much...
FYI: my p1 and p2 start buttons are supplied by ultimarc... dont know where andi gets them from tho.. (presumes happ)
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: 1P buttons
« Reply #7 on: January 21, 2008, 03:11:41 am »
Did you purchase them directly from Happ? Or a reputable retailer?
I use Happ 1 and 2ups and they are fine. Also, they will be screen printed and not painted.
ideft
Re: 1P buttons
« Reply #8 on: January 21, 2008, 06:40:34 pm »
Between a 2 and a 4 yr old and a job, I'm lucky to get to play once a week.  So it is not from over use.  Mine symbol was painted on, I could take it off with my fingernail(just tired on 2P) because it now looks like a plain white button.  I also bought it from Starburst Coin Machines who is a distributor of Happs  products in Canada, so it was from a reputable source.
