Main > Main Forum
Where to buy a 3" clear trackball
jdjuggler:
Actually, yes, I'm very aware of acrylic juggling balls. I don't think they have the weight of the trackball, but I may have to give it a try.
Thanks.
u_rebelscum:
--- Quote from: jdjuggler on May 16, 2003, 11:43:28 pm ---Actually, yes, I'm very aware of acrylic juggling balls. I don't think they have the weight of the trackball, but I may have to give it a try.
Thanks.
Yes, I believe they are lighter than the white trackball balls; but the colored balls at happs are also lighter than the whites, IIRC (or is it just the transparent balls?). Never the less, contact juggling balls are on the hefty side, and probably are about the same weight as the transparents at happs. It's the juggle juggling balls that are a lot lighter than the same size TB balls.
But IANACJ (I am no a contact juggler), so I'm not possitive on the exact weights; my knowledge is from the REAL juggling side. ;)
AX:
i am currently usingone and also TheDemo is. As far as I can tell they are exactly the same wheith and diameter. for half the price it is perfect.
