Main > Software Forum
Which Frontend to use?
Pages: << < (8/8)
ripsnort:
You really should take a look at 3d arcade not many pepole seem to mention it. unlike it says on wiki it will run any emulator not just command line based, it is totally changable with as many menus as you can want. And the the best thing is you can download it already configured all you have to do is insert the roms in the right files add a few background picks and your done . I have about 10 different emulators running from 3d arcade, it also has a 3d option in which you can navigate through arcades walk up to the machines and play them through mame, it also runs pc games aswell.
Check it out
http://echo.messageboard.nl/2243/viewtopic.php?t=1895
headkaze:
3d arcade still kicks arse :)
Popcorrin:
Yea, I love 3d arcade.  The only thing I wished it had was ledwiz or pacdrive support. )p( was going to add it to his scripting engine but he is pretty busy with real life and doesn't have much time to tinker with the frontend anymore.
Headkaze, would it be impossible to adapt your ledwiz plugin for gameex to another frontend?
headkaze:
--- Quote from: Popcorrin on January 22, 2008, 10:20:08 pm ---Yea, I love 3d arcade.  The only thing I wished it had was ledwiz or pacdrive support. )p( was going to add it to his scripting engine but he is pretty busy with real life and doesn't have much time to tinker with the frontend anymore.
I was thinking of adding LEDWiz/PACDrive support to CPWizard a while ago which works with any front end but I'm not 100% sure I'll still do that. The main problem is having buttons light up when you scroll through games. There still needs to be communication between the FE and my program.
ripsnort:
if led wiz can be added to 3d arcade then thats it, game over for the rest of the frontends, 3d arcade just rocks.
Pages: << < (8/8)
Go to full version
