Main > Everything Else
Asus EEE Mini 7 inch screen laptop is a dream
<< < (6/7) > >>
Howard_Casto:
Well area 51 (if you've got the chds handy) would be chugging.  The problem with mame is there is a huge jump in performance.... a 1 gig processor will handle 90% of the games and the one's it won't handle, for the most part need a 4+gig intel processor.
Howard_Casto:
About the magnet, couldn't you just put a stiff piece of plastic over it?
NiN^_^NiN:
I'll try to get the area 51 files soon to test
And no the magnet is used to turn a reed switch off so the pc can't be turned on while the pc is closed its just using the magnetism so you would need to somehow block that and i have no idea how to do that one really
Samstag:
--- Quote from: NiN^_^NiN on January 23, 2008, 10:51:51 am ---And no the magnet is used to turn a reed switch off so the pc can't be turned on while the pc is closed its just using the magnetism so you would need to somehow block that and i have no idea how to do that one really
Wouldn't it be easier to change the power options to allow it to run while closed?
abrannan:
Not to interrupt the performance questions about the EEE, but I saw this site today:
http://beta.ivancover.com/wiki/index.php/Eee_PC_Internal_Upgrades
Where they effectively add on to the EEE using extra available space in the case (yes, there actually is enough space left inside to add components).
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
