Main > Everything Else
Truck won't start
missioncontrol:
turn the key like you were starting it and short the solenoid....
ChadTower:
Welcome back, Paige!
NIVO:
pull the battery posts off and inspect them if you havent done so. I had the problem with the truck. You couldnt see the buildup from just lokking at it, but once pulled all the caking was everywhere. Once replaced($7) it was perfect again. YMMV.
MaximRecoil:
--- Quote from: paigeoliver on January 11, 2008, 02:27:54 am ---No I haven't tried that. It was sort of raining out when I was messing with it, and I didn't want to ruin any clothes crawling underneath the thing or wherever the solenoid is.
--- Quote from: MaximRecoil on January 11, 2008, 02:20:50 am ---Have you tried jumping the solenoid? That can help narrow down the problem.
I don't know how it is on your vehicle, but on many vehicles the solenoid is mounted right on the inside of the fender, easily accessible from under the hood. And like Missioncontrol mentioned, make sure the ignition switch is on before jumping/shorting the solenoid.
ChadTower:
Is this the same truck you bought from Drew? :)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
