Main > Main Forum
Is there a way to wire a joystick so . . .
Pages: << < (2/2)
shmokes:
--- Quote from: The_Roker on May 29, 2003, 05:35:19 am ---So they both have to have the same ground?
But this would be a non-issue if you're chaining all of your grounds together in one big loop.....................................................right?
Tiger-Heli:
I don't think X-Arcade uses a common ground for their encoder.
Your easiest option is to see http://www.xgaming.com/htm/programming.shtml and program the lower left button from C to X and the P2 lower left button from "Close Brace" to Q.
Alternately, you could wire the C button to the same inputs on the circuit board as the X button, but this would be more work and void your warranty.
Hoe:
I just looped a wire going from L to the other L (like how one would loop grounds).
u_rebelscum:
--- Quote from: armad1ll0 on May 15, 2003, 03:47:47 am ---yup, just wire one to the other's contacts.
Simple right? imagine it as a the grounds go to both and the positive is split to a Y and goes to both "L" buttons.
I thought it didn't make a difference if the split was at the encoder, a Y before the switches, or as a daisy chain.  Aren't the following 3 schematics equivalent?
  _____b1____gnd
eL/
  \_____b2____gnd
     ___b1____gnd
eL__/
    \___b2____gnd
      b1______gnd
eL___/\
       \_b2___gnd
Pages: << < (2/2)
Go to full version
