Main > Everything Else
Questions about 1080p
ahofle:
--- Quote from: Howard_Casto on January 08, 2008, 03:48:34 pm ---
--- Quote from: ahofle on January 08, 2008, 01:02:42 pm ---Remaster from original cells.
No... they re-scanned the original film from the archives, the original cells weren't touched, nor do they exist anymore.
I wasn't aware there was a difference. Isn't a cell just a frame from the original film?
Anyway, I think the point is that they sampled the original film instead of just upconverting the laserdisc source (at least that was Chad's question).
http://www.digitalleisure.com/contents/DVDRom_games.htm
"Fully interactive gameplay digitally remastered from the original film"
MaximRecoil:
--- Quote from: ahofle on January 08, 2008, 05:40:32 pm ---
No, the animation cells are the hand drawn/painted clear sheets of "paper". These are photographed in a certain order to make the film.
In any event, if they scanned the original film to make a new digital master, and then made an HD encode from that; it would definitely be an improvement over the laserdiscs (especially if they restored/cleaned the film [if necessary]). This is the same process used to make HD movies from live-action films.
ChadTower:
--- Quote from: ahofle on January 08, 2008, 05:40:32 pm ---I wasn't aware there was a difference. Isn't a cell just a frame from the original film?
This is a case where animation differs from live action. Obviously in live action you can't reshoot the footage so the film is as far back as you go... with animation, if the original hand drawn cels still exist, you can remaster from those and essentially recreate the footage in a pure manner.
Jouster:
--- Quote from: shmokes on January 08, 2008, 03:58:15 pm ---It all works the same with a projector. However, resolution is probably especially important with a projector for no other reason than screen size. Just as people say that you can't tell the difference between 1080p and 720p with a 40" screen or less (notwithstanding Howard's opinion), 1080p is going to be more important at 120" than it is at 50". Larger screens need higher resolutions or the pixels are big and the images are blocky.
That is an excellent point, and one I had not really thought through. A woman may look hot from a far...but as you get closer, you can see the effects from the ugly stick...but if you look at her with a magnifying glass...you can see the backward 'Made in China' indentations on her from the stick.
Jouster
patrickl:
--- Quote from: Jouster on January 09, 2008, 08:59:39 am ---A woman may look hot from a far...but as you get closer, you can see the effects from the ugly stick...but if you look at her with a magnifying glass...you can see the backward 'Made in China' indentations on her from the stick.
Ehm ... a chinese woman was recently voted miss world :P
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
