Author Topic: 7 button layout conflicts with Neo Geo Layout  (Read 2683 times)
  • Last login:October 20, 2023, 11:39:06 pm
« on: January 03, 2008, 03:41:38 pm »
I received my i-pac 4 in the mail yesterday and I was playing around with my button layouts and then realized that I may have a conflict with NEO GEO games.
Currently the 7 button layout I want to have is exactly the same as pictured below.  Button # 1 is on the top and button # 7 is the extra one on the bottom.  This layout is a must since I play Mortal Kombat 3 very often.
However, this 7 button layout does not work well with NEO GEO games.  I would like the A button to be # 7, B button to be #4, C button to be # 5 and D button to be # 6 to conform to the standard NEO GEO layout.
I don't want to have to change EVERY SINGLE Neo Geo game config by using Tab in MAME.  Is there an easier way to do this in an .ini file somewhere?
I've thought about using a standalone Neo Geo emu which would solve my problem, but I really would prefer if it runs in MAME.
Thoughts?
~ D
« Last Edit: January 03, 2008, 07:20:12 pm by DeLuSioNal29 »
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
Re: 7 button layout conflicts with Neo Geo Layout
« Reply #1 on: January 03, 2008, 03:50:32 pm »
Well, on my TEST CP, I have my buttons reversed (according to your picture)
On the bottom rom I have #1, #2, #3
Then on the top row #4, #5, #6
I plan to add a seventh button for the Neo Geo layout.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #2 on: January 03, 2008, 04:06:33 pm »
I did mine slightly different, the #7 button is beside my start button, sorta like a select/start combo.  I use 1,2,3,and 4 for neo-geo games, and it feels comfy using the thumb to hit button 4.
« Reply #3 on: January 03, 2008, 04:49:41 pm »
I would like the bottom 4 buttons to match the Neo Geo layout because that's how the directions on each game displays it when playing.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: January 03, 2008, 05:18:46 pm »
I don't see what the problem is. Go into the MAME menu and define the controls for ALL games rather than for an individual game.
NO MORE!!
« Reply #5 on: January 03, 2008, 05:31:50 pm »
But that would blow away the original 7 button layout which I want for all other games.  I just want the bottom 4 for Neo Geo games.
~ DeLuSioNaL
Daniel B.
  • Last login:April 29, 2024, 11:30:31 pm
  • Lightgun and Point Blank enthusiast
« Reply #6 on: January 03, 2008, 07:43:33 pm »
Couldn't you set the neo-geo friendly layout to ALL GAMES and then set mortal kombat up differently? Or would that throw everything off?
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
« Reply #7 on: January 03, 2008, 07:49:35 pm »
I considered that, but yes, it would throw all the games off.  For example, all games would have the #7 button as button # 1.
polaris
  • veni vidi congai
« Reply #8 on: January 03, 2008, 11:30:34 pm »
isnt it opossible to have two versions of mame, outputting to the same game lists. have one mame version just for neogeo and you could change the controls for that mame version?
gatordad
  • Trade Count: (+11)
  • Last login:March 29, 2024, 07:11:02 pm
« Reply #9 on: January 03, 2008, 11:44:29 pm »
There is a solution I just read it, but I can't find it at the moment.
It went something like this. This may not be accurate as it's from memory
Open and run a single neo geo game
remap your controls to your preference
then copy that cfg file to the neo geo bios or system file I can't remember everything but that was the basic concept.
Then the remap is only active for neo geo games
You can do it the answer is here somewhere.
If I find it I post the link
gatordad
« Reply #10 on: January 04, 2008, 01:03:41 am »
found it
http://forum.arcadecontrols.com/index.php?topic=73373.0
and another one with headkaze neo geo control setup file attached.
http://forum.arcadecontrols.com/index.php?topic=73532.0
« Last Edit: January 04, 2008, 01:08:01 am by gatordad »
