Main > Main Forum
Drilling holes for coin door
Pages: << < (3/3)
Chris:
That looks like a pinball door... hmm... maybe you could find more info on Goole if you search for mounting a pinball coin door?
--Chris
mpm32:
I have the same door but 2-player.  You use carriage bolts to attach it.  When cutting the hole you should make sure it's not oversized.  Use washers on the bolts to distribute the clamping force better and you'll be fine.  If you cut the coindoor hole too big then you can either make a new peice for the door or, get some flat metal 1" wide stock at home depot. Cut a piece for each hole about 2" long.  Drill a hole through the metal near one end the size of the carriage bolt.  Use these in place of a washer.  You are making tabs to extend further out from the hole.  Make the piece like this;
 ___
 | O |
Forgive the artwork.
Pages: << < (3/3)
Go to full version
