Author Topic: Sound effects on game startup etc  (Read 1285 times)
mike_bike_kite
  • Last login:January 07, 2023, 05:16:39 am
« on: January 01, 2008, 04:07:59 pm »
I'd like to add a sound effect when a game begins (something like "prepare to die sucker" in some alien voice). I'm using mame and AtomicFE as the front end. Any ideas how it's done?
Any good sources for similar sound effects
Mike
  • Last login:October 20, 2023, 11:39:06 pm
Re: Sound effects on game startup etc
« Reply #1 on: January 01, 2008, 06:20:35 pm »
I'm not sure how it works with AtomicFE, but I use Maximus Arcade and when you select a game, it makes a clicking sound when you press the button to enter it.  You can replace that sound with whatever mp3 or wave file you want.
I'm sure AtomicFE will work the same way.  But I am not familiar with that FE.
~ DeLuSioNaL
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
« Reply #2 on: January 01, 2008, 09:48:10 pm »
AtomicFEs default layout has what your looking for (and I belive what your referencing)- it says 'Prepare for battle!'
If you go into AtomicFe\layout\default folder you can change the sound to whatever you want (I think its called intro.wav).  You can then rename your sound clip to what the default layout calls it so the layout knows to pull your specific sound... or just use AFEs layout editor to redo your layout and incorporate a new sound.
Tek
Your screen name has been added to my frag list.
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #3 on: January 01, 2008, 11:21:28 pm »
MALA will do it also...Mine says "Destroy the humanoid" when you start and "Chicken fight like a robot" when you exit the game.
Xam
Can't talk to a psycho like a normal human being.
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #4 on: January 02, 2008, 12:23:04 am »
Here's a question, maybe along these lines, maybe not:
How would one go about having sound effects play on the start up *of the cabinet itself*? (ie: as soon as you turn it on, and before the OS loads)?
I've been thinking I'd like to have a power-up sound when I turn on the cabinet. Are there any quick and dirty external "sound devices" one could use?
Xam
« Reply #5 on: January 02, 2008, 01:15:14 pm »
Not sure on that...I have mine saying "coin detected in pocket" on WIndows start, but I'm not sure how you would make it do it before the OS loads.
Xam
mike_bike_kite
« Reply #6 on: January 02, 2008, 04:26:22 pm »
Thanks for help - it's working now.
(prize goes to Teknique)
Mike
