Author Topic: Quick help needed for mala game lists  (Read 1006 times)
gatordad
  • Trade Count: (+11)
  • Last login:March 29, 2024, 07:11:02 pm
« on: December 31, 2007, 10:50:48 am »
I used romlister to create a mala game list of mature games,  but how do I filter my newly created list, it just shows up as a selectable list. I want to filter these before tonights party.
Lakersfan
  • Last login:February 05, 2024, 12:16:07 am
Re: Quick help needed for mala game lists
« Reply #1 on: December 31, 2007, 12:42:38 pm »
Use RomLister in Batch file mode using "del %rom%.zip" instead of the default the program gives you. Use RomLister to get the list of mature games you want to get rid of. Output it to "File" and save that batch file in your roms folder. The go to your roms folder and double click that newly created batch file to delete those mature games. Then open mala and refresh your game list.
This will completely delete them, though. If you only want to temporarily move them, then you'll need to change your batch file command using something other than "del.%rom%.zip". (Someone else will need to chime in with the batch file command as I'm not sure if "cut %rom%.zip c:/mature" would work.
gatordad
« Reply #2 on: December 31, 2007, 01:09:57 pm »
Thanks I do not want to delete but just filter.
shock_
  • Last login:January 30, 2020, 06:23:29 pm
  • In Brisbane, it's GMT+10 all the time.
« Reply #3 on: December 31, 2007, 05:15:37 pm »
Just rename them.
instead of "del %rom%.zip"
use
"ren %rom%.zip.mature"
As long as MaLa only looks for ".zip" files as ROMs it will ignore the .zip.mature files.  This is the way it works by default.  All your files are still there, and can be renamed again trivially if you need them back again.
shock_
« Reply #4 on: December 31, 2007, 08:43:31 pm »
... and don't forget to regenerate your gamelist in MaLa :)
gatordad
« Reply #5 on: January 01, 2008, 02:57:59 am »
Thanks guys, after a search I found this thread for a solution
.http://forum.arcadecontrols.com/index.php?topic=72344.0
« Last Edit: January 01, 2008, 03:00:01 am by gatordad »
gatordad
« Reply #6 on: January 03, 2008, 12:00:15 am »
What do ya know, it's on the Wiki also.
http://wiki.arcadecontrols.com/wiki/Mala_Creation
