Main > Main Forum
Can I swap parts out of an X-Arcade Solo for Happs parts?
Pages: << < (2/2)
The_Roker:
I don't get it, so can I swap out the joystick or are there demension problems?
I know what you mean about the layout conflicting with your hand.  Like I said it should be like this
  x x x
  x x x
x
as opposed to this:
  x x x
  x x x
x x
   ^That button shouldn't be there
I will more than likely plug it then.
armad1ll0:
I'm very confident that you can dirrect swap the sticks out.
If not then you can always just rotate the stick 90 degrees and mount it the other way with screws. There is no need for bolts actually. I assume that arcades use bolts because changing out the sticks all the time would wear the hole out.
The_Roker:
thanks for the replies
I'm still stuck between this and the Mas Systems Joystick.
armad1ll0:
If you are just using the case, then get a Redoctane. For $30, plus shipping, you can't go wrong.
Look on my site for a bunch that I've converted.
Pages: << < (2/2)
Go to full version
