Main > Everything Else
Any use for hex editing with Mame or other emulators?
<< < (2/2)
ChadTower:
I assume he's talking about altering ROM images and not MAME itself, mostly because you're right, the source is available and so a hex editor is irrelevant.
That may be a bad assumption on my part.
Cakemeister:
The cheat system in Mame works by monitoring memory locations known to be home to key game information, such as the number of lives left or whatever.
If you want to modify the actual game to display "Tommy XYZ" instead of "Game Over", rather than modifying the emulator, that is doable with a hex editor subject to the checksum restrictions Ray mentioned.
More complicated still is the new Donkey Kong code which implements new levels using the existing sprites.
I personally would like to extend Galaga to include "tripleship" support and a screen saver. That would be a fun project, and it would be super cool to load those roms into my Galaga machine at home.
Jdurg:
Also, if your ROMs have some type of encryption/compression in there, which most ROMs typically do, it's not an easy "read this and change that" type of change.
Navigation
[0] Message Index
[*] Previous page
Go to full version
