Author Topic: Does anyone use M.E.S.S ?  (Read 1121 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: December 23, 2007, 12:04:00 pm »
So I never messed with it, but I was wondering if anyone has messed  with it? Are you better off using a frontend and importing more than one emulator instead?
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
Re: Does anyone use M.E.S.S ?
« Reply #1 on: December 23, 2007, 12:07:45 pm »
Ok i'll bite what is mess.
Other than my workshop after a project.
There are three kinds of people in the world those that can count and those that can't.
BORIStheBLADE
« Reply #2 on: December 23, 2007, 12:16:45 pm »
stealth1290
  • Last login:March 07, 2008, 08:09:37 am
« Reply #3 on: December 23, 2007, 12:18:32 pm »
wow... quite the emulator!
BORIStheBLADE
« Reply #4 on: December 23, 2007, 12:34:14 pm »
I heard someone at another forum mention it, but I don't see anyone on here talk about it. I figured if it was worth using people on here would be using it.
WaRpEd
    • Warped products
« Reply #5 on: December 23, 2007, 12:44:02 pm »
Sorry I haven't MESSED with that emulator yet. >:D
hbm*rais
  • Last login:September 03, 2010, 08:43:44 pm
  • Relaxen und watchen das blinkenlichten!
« Reply #6 on: December 23, 2007, 01:07:14 pm »
MESS is fine for some systems. Specialized emulators will have greater compatibility and will be faster and more faithful to the original console or computer. Some systems that MESS try to cover simply don't work at all at this moment (Odyssey 2 and PCE, for instance)
As a rule of thumb, I use MESS (with MALA as a frontend) for everything. *IF* I'm not satisfied with the compatibility on a certain console, then I go and find myself a specialized emulator for that.
The great thing about using MESS is that you have a common interface (tab menu, etc...) to all your emulators and it is very similar to MAME.
On a side note, MAME Plus is incorporating some of the MESS drivers, which I think is a great idea. I hope they go on with it and incorporate all the working/stable MESS drivers.
BORIStheBLADE
« Reply #7 on: December 23, 2007, 01:17:35 pm »
So this emulator would be good for NES,SNES etc?
hbm*rais
« Reply #8 on: December 23, 2007, 05:29:15 pm »
Well, mostly yes, from my very limited experiments. Thou one of my favorite games on the SNES (Zombies Ate My Neighbors) has some graphic glitches during the presentation, the rest of the game runs fine.
My point is: If you have some experience setting up MAME + MALA (or any other front end), MESS is very easy to set up. Just install it and try it first with every system you want. If you find out that it doesn't work propoperly, then go find yourself a good specialized emulator.
telengard
  • Last login:May 01, 2024, 04:25:48 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #9 on: December 24, 2007, 12:59:57 am »
MESS is an excellent emulator (well multiple emulator system).  Some of the systems it emulates it does quite well (ColecoVision, TI99/4a, and many others).  I have ported it to the gp2x handheld and have done work on the Odyssey2 emulation system.
It's great that people in here are using it.  I also agree about the specialty emulators.  In my set top box I use something other than MESS for NES games.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
