Main > Main Forum
Single switch for monitor and PC off/on?
Pages: << < (2/2)
pharaoh:
Thanks guys!  My problem has been solved.  I will use the "G3 enable" switch in the BIOS to get the job done.  It's basically a "resume after power failure/removal" switch like hyiu recommended (thx!).  Even if the BIOS doesn't have the setting, I can use a PCI-space editor to flip that bit and enable it (Intel board).  That way, a single switch inline with the power strip will do the task I am looking for.
Appreciate all the help on this!
radiator:
--- Quote from: hyiu on May 13, 2003, 01:57:47 pm ---in there... you can select if AC power resume,
startup your computer....
groovy!
i didn't know that existed...i normally never go into the power option in BIOS...
mine also has the option of powering up after any key is pressed...think i'll use the power resume option though
Pages: << < (2/2)
Go to full version
