Main > Everything Else
Poll: Emergency power and heating
<< < (18/19) > >>
tommy:
I find that post very offensive and I may consider reporting it to a moderator at a later date.   ;D
CheffoJeffo:
--- Quote from: tommy on December 17, 2007, 07:54:27 pm ---I may consider reporting it to a moderator at a later date.   ;D
Slacker ....  ;D
Edgedamage:
They also have conversion kits to make gas generators run off the home natural gas / propane supply.
knave:
After looking into this a bit, I would for sure need a generator.  the blower and ignition controls would eat through any battery system...My last house had a wall furnice so it was all convection...I didn't even think about the huge blower that moves the air around the house.  That said, Someday I'll pick up a generator but I could then just as easily heat just one room with a space heater.  Plus it's not that cold here, so the fireplace would probably do. (it's actually an insert and can put out a bit of heat (in that one room.)  I'm still more worried about a fresh water supply if there were any sort of major disaster.
Something to think about.
ChadTower:
Would you be able to function with just the ignition/control and no fan in an emergency situation?  I'd MUCH rather temporarily be forced air instead of blown than to have to deal with gas/generator/dude swapping it with a mower.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
