May 09, 2024, 09:08:19 am
So where the Wico sticks considered the best of the best of joysticks? That's kind of what I've been hearing. Too bad they're no logner around.
thanks right?Last actuator use microswitch with plain lever? how Happ Super?
ehm conical is only rickety 4way mode...
I got today WICO Leaf Switch and I have stupid problem;)I disassamble stick and I do not remember the sequence of elements someone has original manual diagram?shaftwasherplastic slavemetal slave rubber ring (which side? higher or this flat up/down)spring actuatorE-clipEDIT: I found http://www.crazykong.com/manuals/FWorlds.man.pdf
the largest Wico defect: they crunch. shaft comes in pivot (or ring) too loosely. these elements are bad fitting.
