Author Topic: what type of Potentiometer is this ?  (Read 3149 times)
janey6152
  • Last login:July 31, 2016, 03:39:36 pm
« on: December 04, 2007, 06:49:04 pm »
 trying to see if i need a new one so i can get it work on my mame.
« Last Edit: January 24, 2008, 11:03:16 am by janey6152 »
fjl
  • Pixels Rule!
Re: what type of POT is this ?
« Reply #1 on: December 06, 2007, 02:15:33 am »
Blasphemy! I thought you where talking about a different type of pot...  :-\
Well I can't tell just by looking but I believe there are two types of potentiometers. The resistive powder film type and the resistive wire type. I'm pretty sure I'm way off on what they are really called. But regardless you can tell the difference simply by turning the knob. If it turns smooth then its the resistive powder. If it feels kind of bumpy/scratchy then it is the resistive wire. But from the looks of it, it looks like the resistive film type.
If your trying to find out the value then use an ohmeter on the two outer pins. That will usually give its total resistive value when the dial is set to its max. You can tell if its bad if the value shoots either up or down while turning the dial then goes back to the previous value after a little more turning. This means it has a burned spot when it went bad. There are some cheap pots that have an exponential point. Basically the value has a drastic change towards the end. Those are usually the cheap ones and I doubt they would use that type for a controller.
janey6152
Re: what type of Potentiometer is this ?
« Reply #2 on: January 24, 2008, 11:04:50 am »
OK Need help I bought a DB 15 pin to USB cable.  And My PC is not picking up the connection from wheel .
Chris
    • Chris's MAME Cabinet
« Reply #3 on: January 24, 2008, 11:07:25 am »
Is it picking up the buttons?  PC game ports expect a 100k pot; most arcade pots are 5k.
--Chris
janey6152
« Reply #4 on: January 24, 2008, 12:23:02 pm »
no nothing.  can i replace the  Potentiometer??
 But i don't understand it was used on a pc I quess? I bough this on Efay .
Chris
« Reply #5 on: January 24, 2008, 12:27:26 pm »
If it's not picking up the buttons then this has nothing to do with the potentiometer.  It's an interface or driver problem.
--Chris
Chris
« Reply #6 on: January 24, 2008, 01:32:34 pm »
What kind of interface cable did you get?  Did it come with any drivers?
Some USB to DB15 adapters have different modes to emulate different types of sticks.. perhaps yours isn't in the right mode?
--Chris
janey6152
« Reply #7 on: January 24, 2008, 01:50:07 pm »
No driver this is the one i got ..
Chris
« Reply #8 on: January 24, 2008, 02:48:55 pm »
Did Windows detect it as a game port?
--Chris
janey6152
« Reply #9 on: January 25, 2008, 07:27:43 pm »
Nope .. nothing..
janey6152
« Reply #10 on: May 12, 2008, 05:23:27 pm »
wow , U know i still havn't been able to get this dam wheel to work.. sucks..
