Author Topic: dreamcast vga adapter at 15hz?  (Read 2454 times)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« on: December 03, 2007, 12:29:44 am »
I was looking into the dreamcast vga adapter for my cab, but would it run on a 15hz arcade monitor. probably not right?
Austin.Wolff
  • Last login:February 04, 2011, 03:53:32 pm
Re: dreamcast vga adapter at 15hz?
« Reply #1 on: December 03, 2007, 12:40:03 am »
Uhh I don't know how that works, but worst comes to worst...if you are running a PC, just get a video input card and plug into your comp with your dreamcast.
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
« Reply #2 on: December 03, 2007, 02:48:41 am »
Dont use a VGA box for your arcade monitor at 15khz. You need to hack the rgb scart cable. Look here bags of help:
http://www.mameworld.net/pc2jamma/arc_dc4.html
When pixelated clipart just wont do, just call for Betty
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« Reply #3 on: December 03, 2007, 05:26:26 am »
Yeah, the VGA output from the DC is 640x480@60hz = 31-32 kHz.
« Reply #4 on: December 03, 2007, 05:47:04 am »
You CAN use a VGA box to output @ 15khz but you will need to hack it (very easy to do).
http://arcadecontrols.com/arcade_consoles.shtml#dc2arcade
waveryder
« Reply #5 on: December 03, 2007, 09:04:48 am »
Doesn't that defeat the purpose of using the vga box :dizzy:
« Reply #6 on: December 03, 2007, 11:38:03 am »
Yes...but it is a very easy way to hook your Dreamcast to an arcade monitor (which I presume the original poster wants to do).
Also, IMO this looks better than a DC on a VGA monitor (in most games).
northerngames
  • Trade Count: (+18)
« Reply #7 on: December 03, 2007, 01:54:38 pm »
if you have the clear plastic boxed vga box you cut wire 6 inside the box and it puts it in permanent 15k mode add a standard switch to it and then it can be switched between tv vga and cga  ;)
Frosty
  • Last login:December 30, 2021, 11:11:38 pm
« Reply #8 on: December 10, 2007, 03:34:37 pm »
Yes to all questions.  I did a post on using a simple DC VGA cable hack to get a 15kHz output...
mrserv0n
« Reply #9 on: December 10, 2007, 03:53:31 pm »
Great, thanks Frosty!
  • Last login:Yesterday at 08:03:14 pm
« Reply #10 on: December 10, 2007, 04:07:50 pm »
I use a hacked VGA box to hook my DC to my 25" arcade monitor (Mortal Kombat), and it looks REALLY nice.
