Main > Main Forum
Nintendo 3 in 1 machine ??
MaximRecoil:
--- Quote from: DaveMMR on December 04, 2007, 06:18:51 pm ---
--- Quote from: WareWolF on December 03, 2007, 06:43:19 pm ---
I think it would do better if they would have put VS. Super Mario Bros on it instead of regular Mario Bros though.
Then they would have had to use two different types of joysticks (4-way and 8-way). ;)
Super Mario Bros. only needs a 4-way. If it had ever been released as a dedicated arcade game it most likely would have come with a 4-way. In fact, it only uses 3 directions (left, right, and down). If it wasn't for big Mario's ability to duck or go down pipes, it could use a 2-way, same as Mario Bros. used.
Edit: Strike that, I forgot about climbing vines. SMB does use all 4 directions.
Since it was only ever released on "Jack of all trades" systems (NES and VS. system), it had an 8-way because those systems were made to be compatible with a variety of games, some of which required an 8-way.
If I had a VS. system set up for SMB, I would use a 4-way (same deal for any of the other 4-way VS. games such as Excitebike).
DaveMMR:
--- Quote from: MaximRecoil on December 04, 2007, 08:42:39 pm ---
Oops, your right. I alway think 8-way because I'm one of those people who intuitively holds the joystick up-right when jumping over a large pit. But it does nothing, I know it. Also, because it seems running right then "sliding" (pushing down quickly) would be harder to pull off with the a restricted stick (but I've never tried it).
I'd still personally leave it Mario Bros. though. SMB is more fun on the couch I've noticed.
MaximRecoil:
--- Quote from: DaveMMR on December 04, 2007, 09:21:55 pm --- Also, because it seems running right then "sliding" (pushing down quickly) would be harder to pull off with the a restricted stick (but I've never tried it).
The shortest distance between two points is a straight line. A diamond-shaped 4-way restrictor makes a straight-line path from left or right to down, very easy. 4-ways excel at those types of direction changes—think: Pac-Man.
DaveMMR:
--- Quote from: MaximRecoil on December 04, 2007, 09:49:27 pm ---
Hmmm, makes sense. Now I want to try it out.
Donkey_Kong:
--- Quote from: WareWolF on December 02, 2007, 11:39:00 pm ---I came across this auction on Ebay, sorta like a Pac Man reunion machine, is this a real nintendo product or somebody's (very nice) project they are trying to pass off as a real arcade game?
Played one of these at a local Casino Arcade. First, I was floored to see it and the MsPac/Galaga Reunion and the Space Invaders/Qix Deluxe Edition.
Going back to the 3in1 DK/DKJR/MB though...
I loved everything about it. I forgot all about the MB being a horizontal and as I recall it was a little different, but still very playable. The other two games were excellent on the big monitor. Loved the feel of that stick they had in there also. GOOD STUFF! I want one...
