Main > Main Forum
4 player CP, where should the 4 way stick go?
Pages: << < (3/3)
Dexter:
I'm curently designing a 4 player CP similar to the slikstik and have been having the same problem as you. The solution I will be using is as follows:
From left to right: L + R asteroids buttons, then 4-way, then fire + thrust with hyperspace below at thumb angle, followed by spinner. The spinner can be moved to the left of the asteroids buttons if it suits better.
The advantage is you have 2 buttons doubling for the 4 way and spinner plus you can easily place the hyperspace button below the asteroids L + R if you're a southpaw.
Hope this helps. I'll post pics as soon as I can.
Dexter
Pages: << < (3/3)
Go to full version
