Main > Software Forum
CPWizard v2.63 Released
Invincer:
Tried out those steps exactly as you said, unfortunately the problems remain, the smaller display is extended to the top over my main monitor at a different resolution. It did not work for me on xp, and now I have upgraded to win 7, but the same problem. it doesn't even try to display. On xp i had to use marquee magician and it worked fine, haven't tried that yet on 7. either way, cpwizard for some odd reason does not want to recognize my secondary display :(
headkaze:
In display options can you select it as \\.\DISPLAY2?
Is the window there and just not maximized? ie. Is it in the task bar? Can you alt-tab to it?
Invincer:
EDIT:
Had another probem on new install of it rotating and had set the autorotate on so that made it do it. Had thought the autorotate was for the second monitor, but cpwiz isnt outputting to the 2nd monitor anyways, so I had yet to see what that setting coud do.
Is there anything I could put into the config to try on the subscreen or anything? Tried it every which way I could think of :(
Nope, no signs of the 2nd display window on taskbar by alt/tab, nowhere. :(
headkaze:
So I'm assuming your Display Options are like the ones attached?
Try turning off "Show Loading Screens" I know they messed with some people before.
Also what version of MAME are you using? If it's really old then it won't recieve the messages from MAME that a game has launched. Right now it has to use MAME's Output System to work which is 0.108 or greater only.
Invincer:
Tried numerous variations, with loading and without, with both mame 136 and 137. Both on xp and win7... i guess it is just something having to do with my dual monitor set up. <SIGH>... loved the idea but I may just have to settle for the marquee magician solution :(
