Main > Software Forum
CPWizard v2.63 Released
Pages: << < (98/145) > >>
headkaze:
That is strange then garnerb350. Another thing to check is if you take a look at the attached screenshot you will see the keycodes circled in red end in PAD and not _PAD. (Eg. KEYCODE_8PAD not KEYCODE_8_PAD). Mame changed these keycodes and I had left some of the old ones in there which is what part of the recent update was supposed to fix. So if your layout doesn't have the keycodes like those in the screenshot then your using the older and incorrect XArcade.xml layout file.
Tiger-Heli:
--- Quote from: headkaze on May 19, 2009, 12:25:18 pm ---Mame's pause key cannot be the same as CPWizard's Show Key. There is a technical reason for it which is not really worth explaining other than to say I've tried to get around it but have not found a way yet.
I need to get on-board with the latest CPW, but the above is only true for current MAME versions.  I use 0.113 and an older-ish 2.18 maybe CPW and have MAME Pause and CPW SHOW set to P and it works fine, so using an older MAME could work also.
headkaze:
--- Quote from: Tiger-Heli on May 30, 2009, 12:04:11 pm ---
This was only true for the pause feature which was only recently added to CPW and unpauses Mame without the need for the diff patch. You can still use the diff patch method and pause and unpause using the same button.
garnerb350:
Headkaze...sent ya the files you needed via email... Lets just say this smiley explains it all.... :dizzy:
headkaze:
--- Quote from: garnerb350 on June 03, 2009, 08:35:13 am ---Headkaze...sent ya the files you needed via email... Lets just say this smiley explains it all.... :dizzy:
At least its working. So you have no idea why it suddenly started working? The Mortal Kombats should be displaying okay (as they do for me using your config). So as I said in email try restarting CPW.
If that doesn't work, I don't know? I think you have a gremlin in your machine  :o
Go to full version
