Main > Software Forum
CPWizard v2.63 Released
Pages: << < (92/145) > >>
headkaze:
Version 2.19 Released
- Now CPWizard can unpause Mame without using a diff patch!
There are now 3 primary ways to use CPW and the new default method will not mess with state saves as it does not use Mame's pause key.
Method 1 (Recommended Default): As per the attached image
Mame Output System ON, Use Show Key ON, Send Pause ON, Pause Mode Message System, Detect Pause OFF
- With these settings CPW uses the Show Key set in the Input Options to display the CPW menu. This means CPW no longer interferes with save state. It also can unpause Mame automatically when you exit CPW. No diff patch is necessary!
NOTE: Using this method you cannot set the Show Key to be the same as Mame's pause key.
Method 2 (Older Method using diff patch):
Mame Output System ON, Use Show Key OFF, Send Pause ON, Pause Mode Diff Patch Method, Detect Pause ON
- With these settings CPW detects when Mame is paused and then shows the CPW menu. To unpause Mame when you exit CPW you need to have the bezel_0126.zip diff patch applied.
Method 3 (For older versions of Mame < 0.108):
Mame Output System OFF, Use Show Key ON, Send Pause ON, Pause Mode Send Keys, Detect Pause OFF
- With these settings CPW sends keys to pause and unpause Mame when you press the Show Key.
doctorhifi:
That works perfectly!  thanks :cheers:
Flake:
Is there anyway I can "print" a copy of my control panel layout I put together so that I could say get it laminated and put at the base of my monitor glass?  I'm looking to have some sort of instruction card setup on my cab and since I'm already designing a layout to use in game I was wanting to use that layout to "label" the buttons and joysticks for use when navigating my menus.
I've tried printing to PDF but it doesnt come out clean and the last letter of each label link cuts off.  I was hoping to get something in a landscape format and sent to mamemarquees to print up.
Has anyone don this before or used this application in this manner?
blind_dado:
How about just using a screen capture program?  Or even "Shift, Print Screen" and your favorite editor?
Flake:
--- Quote from: blind_dado on May 18, 2009, 12:03:02 pm ---How about just using a screen capture program?  Or even "Shift, Print Screen" and your favorite editor?
Thanks I will try this.  I'm pretty noobish when it comes to printing from non-traditional software.
Go to full version
