Main > Software Forum
CPWizard v2.63 Released
Pages: << < (84/145) > >>
TheShanMan:
Oh, I know about that, FC. I've already done all that. It was CPWizard that wasn't configured properly. Thanks though.
One thing I noticed that is unfortunate but not a huge deal is that if you get a high score, then view the hitotext table in CPW, you don't see the score. I realize it's because the .hi file isn't written until you exit mame though, so I'm sure that's something that hitotext and CPW have no control over.
headkaze:
--- Quote from: TheShanMan on March 09, 2009, 11:37:49 pm ---Oh, I know about that, FC. I've already done all that. It was CPWizard that wasn't configured properly. Thanks though.
We could of course add an auto save of the .hi/.nvram to the bezel patch so that it saves when you hit pause ;)
TheShanMan:
Ha ha! One of these days the bezel patch will turn into a rewrite of mame (we'll call it MameHK)! ;)
TheShanMan:
I think I found a bug with analog joystick support. I believe if you disconnect and reconnect a joystick, it doesn't work with CPWizard anymore (moving up and down through the menus). It could also be if the computer suspends and then resumes. I'm not 100% positive which it is but I believe it's the former. You may recall that I have swappable panels, so my u360's aren't always connected. After using a different panel for a while I came back to the u360 panel and now I can't move around in the menus.
Let me know if you can easily confirm this, or if I need to do a little more investigating.
jasonbar:
Hi Headkaze-
I'm finally dipping my toes into the cold waters of control panel viewer programs.  :)
Lame newbie question #1:
I went through your Quick Install Guide: http://members.iinet.net.au/~freeaxs/cpwizard/quickinstall.shtml & got stuck on step 7.  When I select View/Preview, I get an empty box (see attached pic below).
In step 5, I did select my (primary) MAME Exe folder & it filled in all the rest of the lines (except Manuals, PCB, Previews, & Select), then I got the "Loading.  Please wait." screen, as expected.  Ideas?
Lame newbie question #2:
I have about a dozen games that run on about 4 different mame.exes, each in its own folder.  I also have 2 versions of Daphne in 2 other folders.  Will those games be captured in the CPWizard list?
Thank you very much,
-Jason
Go to full version
