Main > Software Forum
CPWizard v2.63 Released
redketchup:
thank's work perfectly
doctorhifi:
I'm still having CPW pop up when I attempt to load or save a save state from within mame.
Was that glitch ever resolved and I just missed it?
headkaze:
--- Quote from: doctorhifi on January 31, 2009, 07:09:33 pm ---I'm still having CPW pop up when I attempt to load or save a save state from within mame.
The only way to solve this at the moment is to set the following option in mame.ini to auto save state.
--- Code: ---autosave 1
--- End code ---
doctorhifi:
I'll give it a try.
thanks
doctorhifi:
I'm using v2.13 and for some reason CPW only works the first time I run mame.
That first time it works as normal- pause brings up the CPW menu and I can select the various items. But when I EXIT from the CPW menu for some reason CPW shuts down completely.
I've looked at the verbose log but I can't see anything obvious, not seeing any error reports.
Thoughts?
